Ostrich v1 and ALDL cable for sale
Old Feb 9, 2014 | 03:14 PM
L98 Z28's Avatar
Car: '92 Z28
Ostrich emulator - SOLDALDL Cable - SOLD
Old Feb 11, 2014 | 12:27 AM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
PMd.
Old Feb 11, 2014 | 12:28 AM
Axle/Gears: Stock
Edit
Old Feb 12, 2014 | 09:19 AM
L98 Z28's Avatar
Car: '92 Z28
Re: Ostrich v1 and ALDL cable for sale
Cable sold. Emulator still available.
Old Feb 18, 2014 | 09:26 AM
L98 Z28's Avatar
Car: '92 Z28
bump
Old Feb 22, 2014 | 09:28 AM
L98 Z28's Avatar
Car: '92 Z28
lowered price
Old Feb 23, 2014 | 11:46 AM
karl's-92'-z28's Avatar
Car: Too many cars
What does the emulator do?
Old Feb 23, 2014 | 11:55 AM
L98 Z28's Avatar
Car: '92 Z28
It replaces the PROM and makes tuning less of a hassle.
With a PROM, you have to remove the chip from the ECM, plug it into a programmer, and then put the chip back in the ECM. With an emulator, you leave the emulator connected to the ECM and quickly reprogram it in the car using a USB cable and laptop.
Old Feb 23, 2014 | 12:11 PM
Car: Too many cars
Pm sent
Old Feb 28, 2014 | 11:16 AM
L98 Z28's Avatar
Car: '92 Z28
Ostrich emulator still available
Old Mar 4, 2014 | 02:17 AM
310cid's Avatar
Car: 92 camaro
Engine: 406
So would I be able to tune my stock prom with out burning a new chip on existing prom
Old Mar 4, 2014 | 10:17 AM
L98 Z28's Avatar
Car: '92 Z28
Right. You remove the stock chip and plug the emulator into its spot. You can then reprogram over USB. Everything can be under the dash with just a USB cable hanging out so you can reprogram when needed. Reprogram can easily be done at anytime.
With a chip, you are constantly pulling your chip, plugging the chip into a burner, and then reinstalling the chip into the ECM. The ECM is probably sitting on the floor for easy access while you do this. You probably can't stop on the side of the road to tweak with a chip because you don't have a chip burner that you use in the car.
The emulator makes it much easier. I got a EBL P4 Flash to replace my entire stock ECU and it programs over USB also.
Old Mar 4, 2014 | 11:53 AM
310cid's Avatar
Car: 92 camaro
Engine: 406
So your say is I wouldn't be able to just change tune on chip and put prom back in I would have to leave the ostrict in place of the prom instead? So what if I put prom back inside the ECM the car will be on stock tune again
Old Mar 4, 2014 | 12:07 PM
L98 Z28's Avatar
Car: '92 Z28
The ostrich emulates a prom and connects where the prom goes. If you have the ostrich in there is no need (or place) for a real prom chip. If you want to take the ostrich out, then you can burn anything you like on a prom (stock or modified tune) and put the prom back in. You can use the ostrich to make tuning easier, and once you have a custom tune that you like, burn it into a prom and remove the ostrich.
310cid's Avatar
Car: 92 camaro
Engine: 406
What do I need to save tune on prom the p4 flasher
Old Mar 4, 2014 | 01:10 PM
L98 Z28's Avatar
Car: '92 Z28
I don't understand your question. The EBL P4 Flash is a replacement ECM, its different than the Ostrich emulator (and much more expensive).
Are your asking how to use the ostrich? Do you already edit and burn your own chips? If so, you edit it the same way, and then use a program to upload to the emulator.
Tuning software like TunerPro RT that allows you to edit the binary and upload to the emulator. You will need serial drivers that allow you to connect to the emulator over USB.
Install instructions are here:
http://support.moates.net/ostrich-operation/
Drivers are here:
http://support.moates.net/troublesho...-installation/
Old Mar 4, 2014 | 01:19 PM
310cid's Avatar
Car: 92 camaro
Engine: 406
Ok so this work for the 7730 ECM right
Old Mar 4, 2014 | 01:20 PM
310cid's Avatar
Car: 92 camaro
Engine: 406
Ok I just didn't understand what they were and function
Old Mar 4, 2014 | 01:24 PM
310cid's Avatar
Car: 92 camaro
Engine: 406
I'm need to this and would like to learn how to tune and burn stuff
Old Mar 4, 2014 | 02:21 PM
L98 Z28's Avatar
Car: '92 Z28
Yes, I used it with a 7730 ECM with an $8D binary and Super 8D (search for S_AUJP_V4_1026 to learn more).
The DIY prom forum should have good information for learning about burning proms.
https://www.thirdgen.org/forums/diy-prom/
Old Mar 4, 2014 | 03:07 PM
310cid's Avatar
Car: 92 camaro
Engine: 406
Pm sent
Old Mar 4, 2014 | 03:25 PM
L98 Z28's Avatar
Car: '92 Z28
Did not receive the pm. please send again
Old Mar 4, 2014 | 09:14 PM
310cid's Avatar
Car: 92 camaro
Engine: 406
Pm me your paypal info
Old Mar 4, 2014 | 09:32 PM
310cid's Avatar
Car: 92 camaro
Engine: 406
Payment sent
87SSTPI
Oct 16, 2008 08:42 PM
formula350sd
24
Jul 17, 2008 10:34 PM
AC
Mar 19, 2008 10:48 PM
Magman
Mar 9, 2008 11:29 AM
Six_Shooter
Sep 14, 2007 06:53 PM
