(Sold) Valve springs and retainers
Car: 1987 GTA
Engine: 383 HSR Procharged
Transmission: TKO600
Axle/Gears: Moser 9", 35 spline Wavetrac 3.89's
Have a slightly used set of small chevy springs. Used for a handful of dyno runs. Set of 16 with 7 degree steel retainers and dampers. Specs are coil bind=1.15", 1.800" 140#, 1.900 118#...330# at 1.200". Spring OD is 1.53". I believe these are the springs I bought some time ago..ISKY 805-DO. They list out around $100-110 without the retainers.. Safely run these with a .500 lift hydraulic cam. These are larger diameter springs than some small chevy's, so your head may need machined to accomodate. You will need a standard set of 7 degree locks with these. $40 picked up or $45 shipped in U.S. I also have a good PS pump from my '87 along with some stock pulleys if anyone is interested. Thanks, Chris. 330-204-4199
On ebay right now..100% feedback!
Car: 1987 GTA
Re: Valve springs and retainers
7 days left on ebay..
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=151294728483&ssPageName=STRK:MEBIDX:IT#ht_124wt_1220
1988iroc350tpi
Aug 14, 2015 07:52 PM
