Welcome to the "I need new intake rocker arms" garage sale
Car: 89 Z28
Engine: 355 full roller, Brodix 10X heads
Transmission: Close ratio Muncie
Axle/Gears: 3.42/7.5
Welcome to the "I need new intake rocker arms" garage sale. I recently broke an intake rocker on my Jesel set-up (way too old with way to much spring pressure)and I thought I'd get rid of the parts left over from the Camaro project. I'll attempt to add pics, or I can send pics if needed. Shipping will be actual UPS ground from 43123 or local pick-up. If you think
the price is high, make me an offer. This list is also posted on frrax.com, as things sell, I'll update the list. Remember, you are helping fund another racer's project!
12 gallon red RCI fuel cell (drag style), no mounting brackets or foam, has plumbing fittings, cleaned and leak tested. $50
33mm 3rd Gen F-body Hollow Hellwig sway bar (bar only) $100
Kirkey 10 degree layback circle track seat, blue tweed cover, 16"wide, good condition. $75
Butlerbuilt 20 degree Layback circle track seat,16" wide, red cloth cover (faded, some wear) fair condition. $75
Used MSD 6A ignition box, used, worked when removed from my Camaro. $50
(16) Comp Cams stock length, SBC, 5/16" Magnum pushrods, part number 7372, nearly new. $50
New SBC long water pump (Advance Auto brand) $15
Under-drive crank and alternator pulleys for a 6 rib serpentine belt (long water pump, I think), stock crank pulley and smooth water pump pulley
Holley HP 830 with repaired base plate, jetted to your specs or I can put it back to stock Holley calibration, 50cc front acc pump kit $375
4 panel circle track rear view mirror $25
Wilson 1" aluminum carb spacer, changeable from open to 4 hole. 4150 flange. $40
4150 to 4500 Holley 2" carb spacer $40
3/4" Mr Gasket aluminum Quadra-jet to 4150 flange adapter $10
East Coast Electric 1 wire alternator for SBC 70amp output, comes with a 6 rib GO FAST CHROME fan and pulley. Nearly new, has a few hundred miles on it. $40
(2) SBC GO FAST CHROME t-stat housings, (1) straight, (1) driver side offset $10
New Jegs adjustable fuel pressure regulator (carb only)
3rd Gen F-body clutch pedals with aluminum pedal pads $75
12v powered, photo cell/reflector triggered, timer set on tripods. I used these when I was testing drag race snowmobiles on grass (insert ******* joke here).
The set contains (1) 500' spool of twisted pair wire, (1) 250' spool of twisted pair wire, (1) start timer with stopwatch (timer), (1) intermediate/split time timer,
(1) finish line timer. These would work great for autocross, rallycross, anything where you need to time a straight line, circle track or
road course (when laptimers aren't available) $200
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
Re: Welcome to the "I need new intake rocker arms" garage sale
Is this the entire assembly?
I'm a little curious about the "Aluminum pedal pads." Do you have any pictures handy?
Car: RS Camaro
Engine: 97 L31 350:Eventually a stroker
Transmission: WC T-5
Axle/Gears: Zexel Torsen 3.73s
Would the underdrives work on a 91 rs serp. system?
Interested in pics of msd setup email to martinez1114z28@gmail.com and also under drive pullies
PayPal ready as well
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
