[Sold] Turbo manifold
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Turbo manifold
Cast martin turbo manifold. This would work well in a stock thirdgen, C3 corvette, or full size truck. In a thirdgen I think the largest turbo you could go with is a TO4S with an on-center exhaust housing. My T76 hits the valve cover and requires a 2" spacer, which puts it through the hood.
I suspect it would be similar on a C3 corvette, but on a full size truck with all the hood-height in the world you could run any size T4 with the appropriate spacer (to clear the valvecover).
Manifold only. You would use your stock manifold and partial y-pipe. Turbo manifold has a standard 3bolt flange for the crossover.
$300 or best offer.
-- Joe
$300 or best offer.
-- Joe
Re: Turbo manifold
TTT
Going on ebay
-- Joe
Going on ebay
-- Joe
Hotrodboba400
12-10-2019 07:07 PM
sailtexas186548
02-17-2017 03:07 PM
86CamaroDan
09-29-2015 10:08 PM
