[OH] AFR Heads, Straight Plug, 64cc
Old Feb 8, 2015 | 06:23 PM
firebrdo88's Avatar
Car: 1988 Pontiac Firebird
Engine: 400 sbc
Transmission: TH400
Axle/Gears: Ford 9" 3.50 35 Spline
AFR Cylinder Head. The Small Port, High Velocity Torque Monster.
190cc intake port small block Chevy cylinder straight plug version, 64cc combustion chamber with a 64cc exhaust port and a 3/4" thick head deck. valves are 2.020 intake and 1.600 exhaust, Center bolt valve covers and 2 center intake bolts at 72º angle. 190cc Street Head Flow (CFM @ 28" H2O. Flow rate at .550 Lift Intake 262 and exhaust 192 rated from AFR. These have Comp Cams Titanium retainers and Comp Cams 977 Springs. The springs and valve seals were replaced in June 2014.. They have been milled to 64cc These have been on my car for many years with zero issues. They still are on my car and I will remove once purchased. currently on 406 sbc and perform great! Made 425hp on a dyno jet 248 N/A last summer and 11.7 in 1/4 mile. $1000.
Attached Thumbnails AFR  Heads, Straight Plug, 64cc-img_2496.jpg   AFR  Heads, Straight Plug, 64cc-img_2495.jpg   AFR  Heads, Straight Plug, 64cc-img_2494.jpg   AFR  Heads, Straight Plug, 64cc-img_2490.jpg
Old Feb 10, 2015 | 09:50 AM
firebrdo88's Avatar
Engine: 400 sbc
Transmission: TH400
Re: AFR Heads, Straight Plug, 64cc
bump
Old Feb 12, 2015 | 08:13 AM
firebrdo88's Avatar
Engine: 400 sbc
Transmission: TH400
The heads are off the car now. I can send pics if anyone is interested.
Old Feb 18, 2015 | 07:46 AM
firebrdo88's Avatar
Engine: 400 sbc
Transmission: TH400
bump
Old Feb 18, 2015 | 06:14 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
so you have drilled them for steam holes
Old Feb 18, 2015 | 06:54 PM
firebrdo88's Avatar
Engine: 400 sbc
Transmission: TH400
Yes they were dilled by AFR. They can still be used on a 350 or 400 bring the gasket for the 350 will cover those holes or if a 400 the gasket will have the holes.
Old Feb 23, 2015 | 02:37 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Sent you a pm.
Old Feb 23, 2015 | 07:13 AM
firebrdo88's Avatar
Engine: 400 sbc
Transmission: TH400
Sorry guys but because of lack of interest I posted these on Ebay. Figured with no real interest here in 2 weeks.
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Feb 28, 2016 03:33 PM
CRFred
Feb 7, 2016 11:39 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
