[CA] ASM 52mm Throttle Body $200 (USED)
Old May 9, 2015 | 01:10 PM
SixSeriesCSi's Avatar
Car: 89 Formula, 85 Trans AM & 91 Bird
Engine: 5.0 CARB, 5.7L TPI & 3.1L V6
Transmission: T-5/700R4/700R4
Axle/Gears: 9 Bolt & 10 Bolt X2
If you're interested I can take some photographs for you,
Old May 11, 2015 | 07:58 AM
flintlocks's Avatar
Want a title? Post!
Car: 46 Chevy truck
Engine: 355
Axle/Gears: 342
Re: ASM 52mm Throttle Body $200 (USED)
How well used is it,, as in how many miles and age and condition. Pics would be great also. Thanks
Old May 12, 2015 | 12:49 PM
Note - Includes a TPIS Throttle Body ID Plate, anodized Jet Black with Stainless Steel Screws, not the Original AS&M ID Plate/Screws (I'm keeping those).
Note - Not Included is a TPIS Billet IAC Housing anodized "BLACK" with Stainless Steel Screws.
Old May 12, 2015 | 02:20 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
well since your keeping all the good stuff how about $10
Old May 12, 2015 | 03:02 PM
Front & Top
Attached Thumbnails ASM 52mm Throttle Body 0 (USED)-20150512_113316.jpg   ASM 52mm Throttle Body 0 (USED)-20150512_113327.jpg
Old May 12, 2015 | 03:14 PM
Front Bores
Attached Thumbnails ASM 52mm Throttle Body 0 (USED)-20150512_113409.jpg   ASM 52mm Throttle Body 0 (USED)-20150512_113537.jpg
Old May 12, 2015 | 03:20 PM
Rear
Attached Thumbnails ASM 52mm Throttle Body 0 (USED)-20150512_113644.jpg   ASM 52mm Throttle Body 0 (USED)-20150512_113700.jpg
Old May 12, 2015 | 03:36 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
I don't think that's an AS&M TB......
Old May 12, 2015 | 04:33 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The as&m bored out 48mm tb's I have had have a anodized throttle blades. This looks like a 85-88 tb with 89-92 wrap around throttle cable end.
Old May 12, 2015 | 10:22 PM
Is there a way of verifying that this is indeed an AS&M Throttle Body?
Old May 13, 2015 | 06:33 AM
Car: 89 Formula
Engine: 383 SBC/HSR
I don't think you can put an air foil in an AS&M TB, and that piece you have is cast, not billet. So I'm pretty sure it's not.
The only thing that looks like it's from AS&M is the IAC.
Old May 13, 2015 | 10:39 AM
Engine: Lb9
Transmission: M20
Tpis, lingenfelter, as&m , eBay you use to be able to get your 48mm bored out.
The 89/92 tb has the iac passage connected to the throttle bores. If this was put on a 89-92 plenum the iac would not be functional to control idle.
There is break through on two holes from boring. The lh side hole wasn't block off with that iac housing. That would cause a big vacuum leak. No one who bored out the tbs marked them with there name.
A air foil needs to have a small amount removed to blend the throttle bores but they were sold with them.
Old May 13, 2015 | 01:56 PM
TPIS, Lingenfelter, AS&M and eBay - you use to be able to get your 48mm bored out.
There is break through on two holes from boring. The lh side hole wasn't blocked off with that iac housing. That would cause a big vacuum leak.
No one who bored out Throttle Bodies marked them with there name.
This is some good information.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
