[GA] debating a part out situation. fishing for interest.
Old Jun 12, 2015 | 01:27 PM
truckerz's Avatar
Car: 1989 Formula
Engine: 355ci HSR SBC
These parts MAY be up for sale soon.
My budget is running woefully thin.
I got screwed by a local shop, big time. So depending on the cost of repair, I'll be fixing it or parting it. ....1989 formula 350
Nothing listed will be inop/unusable.
Stealth ram, complete.
Profiler 185cc/64cc heads. Hydro springs from profiler good for .650 lift. 2.02 / 1.6 valves. Ran 1 hour.
Comp cams 268xfi. Ran 1 hour.
Comp cams pro mags
comp cams pushrods. Ran 1 hour.
original radiator
Dual fans
2 165 ecm , one "chip" from pcmofnc. For the above spec build.
Gm edge 3000 stall converter.
Built transmission (got it from YenkoST from this board, he had it in a pickup that was around 400+hp)
Good bosch maf
An extra iac valve
A set (front and rear) of never installed kyb gr2 shock/struts.
a new ac delco fuel pump.
A "small" distributor with around 2000 miles on our.
Flow tech headers
The Roller that needs paint and a new rear spoiler so bad.
A water pump and starter with less than 500 miles. (Cheap autozone)
2 sets of valve covers, one tall from summit (chrome), and the stockers.
A msd coil
New ( installed and ran for an hour) set of plugs and ignition wires.
The wiring harness from an 89 formula 350 (some cuts/splices)
Stock intake tubing
ac system is inop, but there is an ac delco blower motor with 500 miles on it.
The block, bought from a guy here bored to .030...... If it is viable.
Speed pro pistons, if they are viable
Stock crank and rods, if viable.
Misc interior bits. Good dash pad.
If you are interested pm me.
Based on interest, I'll update this with prices and all the pertinent info.
Old Jun 12, 2015 | 01:52 PM
1991z28camaro's Avatar
Car: 1992 RS Convertible
Engine: 5.0 L 305 TBI
Re: debating a part out situation. fishing for interest.
Price on the (front and rear) of never installed kyb gr2 shock/struts.
Old Jun 12, 2015 | 02:47 PM
edz88irocz28's Avatar
Car: 1988 Iroc-Z28
Engine: TBI 305 Bored 30 over mild Mods
Axle/Gears: Stock
Price on blower motor, And fuel pump got the part # of it..
Old Jun 12, 2015 | 08:10 PM
Red_Dragon's Avatar
Car: 1988 Iroc-Z
Price on stealth ram, complete.
Old Jun 12, 2015 | 09:22 PM
bdiroc's Avatar
Car: 1989 camaro
Engine: 355 tpi
Transmission: 700r
Axle/Gears: 3.50
stealthram late version so it can port to 1206? is it ported already? price?
Old Jun 12, 2015 | 10:46 PM
truckerz's Avatar
Car: 1989 Formula
I'm just getting interested parties now..... part out is dependent on cost of repair. If it is cost prohibitive to repair, I'm going to part it out. I'll know by Monday or Tuesday.
I believe the SR is the old style. It is still on the car. 600+ shipping. Add 100 for fuel pressure gauge and braided lines.
Old Jun 13, 2015 | 03:59 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
interested in the cam and the HSR (lines as FPR and Lines as well)
Old Jun 18, 2015 | 08:36 AM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
I'd be interested in the rocker arms and push rods, depending on size(s).
Old Jun 18, 2015 | 10:13 AM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
How much for the convertor? Any other info?
Old Jun 18, 2015 | 11:19 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
I'd be interested in the heads, are they aluminum?
Old Jun 20, 2015 | 07:48 AM
blue84transam's Avatar
Interested in kyb's
Old Jul 25, 2015 | 11:06 PM
NASCAR's Avatar
Car: 89iroc/03dakota
Engine: 350&4.7
Transmission: auto
Axle/Gears: 2:77 & 3:55
LOOKING FOR REAR END
Old Jul 25, 2015 | 11:42 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Highly interested in dash pad. PM me pics and price pls
Grey interior? post up pics - need a ton of 89 formula stuff.
Old Jul 26, 2015 | 08:22 AM
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
Whats been done to the trans? How much $?
Old Jul 26, 2015 | 01:02 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
Transmission: WC T-5
I'd be interested in an ECM and the chip. What injector size?
Old Jul 27, 2015 | 12:46 AM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
If the stealthram in the new 2006+ one I'd be interesred
Old Jul 28, 2015 | 05:30 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
How much are the heads?
-- Joe
Street Lethal
Apr 30, 2019 12:14 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
