[IA] AS&M Throttlebody, new, mounted but never run on the motor
Old Oct 22, 2015 | 04:02 PM
gixxer92's Avatar
Car: 1986 IROC, 2017 Silverado
Engine: 7.0L, 6.2L
Transmission: Tremec Magnum, 8L80
Axle/Gears: 3:23, 3:55
$350.00 obo
This is for a TPI motor.
AS&M said that they did make it for a period of time. The linkage cam is set for automatic or manual.
Old Oct 22, 2015 | 06:21 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: AS&M Throttlebody, new, mounted but never run on the motor
Nice, if it was for 89-92 i'd be on it.
Old Oct 22, 2015 | 07:03 PM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
What year is that sexy thing for?
Old Oct 22, 2015 | 07:07 PM
gixxer92's Avatar
Engine: 7.0L, 6.2L
From what AS&M said it was 85-59 for sure. You can see the mounts in the last photo (please verify with what you have). it has the clip style kick down and the throttle and cruise control mounts are the C or oh **** (when it goes flying...) clip style
Old Oct 22, 2015 | 08:01 PM
Car: 88 IROC-Z
Ill bite, $250.
Old Oct 22, 2015 | 08:02 PM
gixxer92's Avatar
Engine: 7.0L, 6.2L
Originally Posted by no new tires
Ill bite, $250.
I'll keep it at that price.
Old Oct 22, 2015 | 08:27 PM
Car: 88 IROC-Z
Care to counter offer
Old Oct 22, 2015 | 11:03 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
Pm sent
Old Oct 23, 2015 | 08:03 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I see an iac mounting boss, but don't see any passages for the iac ?
This would be nice for a blown application.
-- Joe
Old Oct 23, 2015 | 08:10 AM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
There's one on the bottom, you can see it in the third picture.
Old Oct 23, 2015 | 08:26 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Ahh. So it's got a hole on the bottom for the iac. Got it. Neat.
-- Joe
Old Oct 23, 2015 | 12:58 PM
gixxer92's Avatar
Engine: 7.0L, 6.2L
More info from Jim at AS&M on the monoblade;
What he said was;
The throttle body's used to be made out of cast aluminum. Approximately 10 years ago they changed their process to billet aluminum (which this one is). It has a stainless steel throttle blade and it has bronze bushings. He said that the stainless steel can handle a nitrous backfire very well if that has any relevance.
Due to the third gen being a low volume item they are made on a request only basis and you have to send in your throttle cam to be fitted on the throttle body shaft. The reason for this is that GM used 5 different throttle/cruise/trans configurations on the C4 Corvette and the third gen F-body. He stated that they don't keep any inventory (overhead) due to costs. The throttle cam on my throttle body appears to be stainless steel and the cable mounts were welded into the throttle cam.
In saying all of this, there is no part number for the throttle body, as I did ask him as well. A majority of the throttle bodies they produce now are for the LT-1 car's and GM's big block ramjet's use the same cable configuration as the LT-1's do.
Old Oct 23, 2015 | 05:07 PM
gixxer92's Avatar
Engine: 7.0L, 6.2L
Pending sale...
Old Oct 23, 2015 | 09:08 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
MMMMM,, TPI ****
Old Oct 24, 2015 | 01:26 PM
gixxer92's Avatar
Engine: 7.0L, 6.2L
Sold, ty Heet Seeker
tbroherd
Nov 4, 2015 08:45 PM
Fishy4Life
Oct 29, 2015 07:25 AM
Buggy Disaster
Oct 22, 2015 08:30 AM
dragonmas
Oct 18, 2015 11:48 AM
