[IL] LT level 4 700r4 trans and PTC 3200 stall nitrous lock up convertor
Old Nov 7, 2015 | 03:13 PM
88GTAbandit's Avatar
Car: 1988 pontiac Trans Am GTA
Engine: DFI,Single Plane,200cc Dart I.E,355
Transmission: Th400 PTC converter
Axle/Gears: Stock Ausie 9 bolt w/3.45 gears
FLT level 4 700r4 trans and PTC 3200 stall nitrous lock up convertor.....
Trans details from the build, has 400 street miles and 20 track passes on motor.. Saw a fastest of 12.2 @112 pass. Convertor has 9 passes on it
FLT machined performance pump.
FLT sleeved input drum
FLT (billet 6061 aluminum) overrun piston
Sonnax SmartShell w/bearing kit
B/W hi-energy 3-4 clutch pack
B/W double caged 29 element sprag
Corvette servo
Alto wide 2-4 red lined band with reinforced anchor
Bushing kit
New solenoids
New Spacer plate
B/W clutches
Seal & gasket kit
Filter
Updated aluminum accumulator pistons
FLT calibrated valvebody with HD 2-3 shift valve modification
Set end play to FLT specs
Also will include Lokar kickdown cable and has an Aluminum Trans pan with drain plug already installed on trans.
Fluid is still nice and red not dirty or burnt up
$1400 obo plus shipping
Old Nov 7, 2015 | 03:19 PM
Re: LT level 4 700r4 trans and PTC 3200 stall nitrous lock up convertor
My email is gtabandit61@gmail.com
Old Nov 8, 2015 | 10:19 AM
Shoot an offer, going th400 with a brake
Old Nov 20, 2015 | 09:26 AM
stealthram92z's Avatar
Car: 92 Z,92 RS,95 SS,00 WS6, 04 XUV
Engine: 383z,350RS, LT1, LS1 ,vortec 4.2
Transmission: 700R4, 700R4,4L60E,4L60E, Auto,
Still have the tranny, what year is it?
Old Nov 20, 2015 | 11:28 AM
Yes I do, its from an 88 trans am gta..
Old Nov 20, 2015 | 02:37 PM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Sent you an email.
Old Nov 20, 2015 | 11:55 PM
TTA656's Avatar
Car: ****TTA****
Engine: Bad A$$ Buick motor
Transmission: 2004r
Who's th400 are you going with
Old Nov 21, 2015 | 06:47 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
What size converter? 9" ?
Old Nov 21, 2015 | 12:18 PM
Honestly not too sure, I sent all my info to PTC (cam specs, motor specs, future plans) and they called and talked with me on what was best, and that was that. I want to say PTC only has 1 size for a 30 spline lockup convertor because I was never asked.
Old Nov 21, 2015 | 02:08 PM
Plan to get the Th400 built by TSI (Transmission Specialties Inc, in Addison, IL)
Out-Cast
Apr 16, 2019 04:01 PM
sleprock
Oct 14, 2015 12:20 PM
crossrush
Oct 13, 2015 08:09 PM
SteelheadBen
Oct 13, 2015 07:20 PM
Derrick86
Oct 13, 2015 07:15 AM
