[MN] ACCEL STREET RAM INTAKE MANIFOLD ALL PROFESSIONALLY PORTED 1,500 OBO
Car: 1986 irocz
Engine: 358dart worldheadsprochargerfastxfi
Transmission: 700r4 1800 stall tci and b&m everyt
Axle/Gears: posi 2.73 highway gears
buyer not pay so i will try again.
1500.00 OBO
PART #’S BASE #74197 (NOW BY EDLEBROCK # 3860)
LONG RUNNERS # 74199 (NOW BY EDLEBROCK #3865)
PORTED UPPER PLENUM
THROTTLE BODY PART # 74137 DUAL 58MM
CORVETTE FUEL RAILS WITH ADJUSTABLE PRESSURE REGULATOR.
ALL BOLTS AND HARDWARE.
MAP SENSOR BRACKET.
I ALSO HAVE THERMOSTAT HOUSING/NECK FOR IT.
ACCEL LINGENFELTER STREET RAM, TUNED PORT INJECTION (TPI):
FULLY PROFESSIONAL PORTED AND POLISHED BY JDS IN GEORGIA (BEAUTIFUL JOB). ACCEL LINGENFELTER INTAKE BASE PORTED TO FELPRO 1205 GASKET TRIMMED TO BLUE SILICONE SEAL BEAD (SAME AS HEADS ARE) PERFECT MATCH FOR AFR HEADS. CAST ALUMINUM.
LONG TUBE ACCEL LINGENFELTER CAST ALUMINUM RUNNERS PORTED AND POLISHED AS ABOVE.
ACCEL LINGENFELTER TUNED PORT INJECTION UPPER PLENUM COMPLETELY PORTED AND POLISHED AS ABOVE AND FOR DUAL 58 MM THROTTLE BODY.
ALL BEAD BLASTED AND PAINTED CLEAR WITH CERAMIC ENGINE PAINT.
HAS HIGHER TORQUE THAN SHORT TUBE MANIFOLD.
I USE FELPRO GASKET MATERIAL ON A ROLL FOR THIS SINCE EVEN THE LARGE MR.GASKET GASKETS FOR THIS ARE TOO SMALL AND NEED TO BE CUT ANYWAYS PLUS ITS CHEAPER TO BUY A ROLL AND JUST GLUE IT TO RUNNER TUBES AND TRIM.
THROTTLE BODY
ACCEL LINGENFELTER BILLET ALUMINUM DUAL 58MM
1,000 CFM FLOW RATING
BILLET ALUMINUM NOT CAST (SUPER STRONG)
THE BEST DUAL 58MM THROTTLE BODY MADE.
1500.00 OBO
PORTED UPPER PLENUM
MAP SENSOR BRACKET.
THROTTLE BODY
Car: 1986 irocz
Re: ACCEL STREET RAM INTAKE MANIFOLD ALL PROFESSIONALLY PORTED 1,500 OBO
SUPER RAM PLENUM AND RUNNERS HAVE BEEN SOLD THIS IS FOR COMPLETE STREET RAM (LONG TUBE) INTAKE WITH HARDWARE AND PARTS AND THROTTLE BODY ONLY.
Car: 1988 Iroc Z28
What would you take on the throttle body it would complement the the super ram or slp setups i have up for sale . And you are correct in my opinion on your assesment of the throttle body it is the best i have one of the original lingenfelter ones that was made before there contract with accel expired and accel started selling them under there name . I would not sale it for anything people that haven't used one of these or personally seen one typically have no clue to the craftsmanship or performance of it hands down way above other throttle body with holley following second way behind and the rest on the market being not much better than stock
Car: 1986 irocz
want to sell as complete set sorry.
Car: 1986 irocz
ttt
Car: 1986 irocz
pics
Car: 1986 irocz
LOOKS LIKE THIS MAY HAVE BEEN EXTRUDE HONED.
IT IS VERY NICE JOB 100% PORTED AND POLISHED INTAKE, RUNNERS AND PLENUM. (BY JDS IN GEORGIA)
HERES SOME MORE PICTURES OF INTAKE BASE.
Car: 1986 irocz
ACCEL RUNNERS 100% PORTED, MAY HAVE BEEN EXTRUDE HONED.
LARGER DIAMETER THAN STOCK ACCEL, MUCH LARGER THAN STOCK GM TPI.
Car: 1986 irocz
Car: 1986 irocz
Car: 1986 irocz
TTT
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
Car: 1986 irocz
there are pics of base and runners above, click on the pic you want to see and blow it up. they are not cell phone pics i took with canon camera.
Car: 1986 irocz
TTT
Car: 1986 irocz
SOLD
92rszz4
Aug 7, 2016 10:49 AM
89irocz355
Jun 6, 2016 10:52 AM
