Holley commander 950 ECM/ harness/software/manual/laptop cable. And 58mm/52mm Tbs ale
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
Hi guys I have a Holley Commander 950 setup for sale. Complete with full harness, software, 97 page manual and laptop cable. I never got around to installing it so I'm letting it go. I have pics just send me your number or email! $450 shipped!! Also have a used BBK 58mm TB 88-89 sitting around $150shipped, a NEW Holley 52mm $225 shipped. Also have pics.
Car: 92 1500p\u 2wd
Re: Holley commander 950 ECM/ harness/software/manual/laptop cable. And 58mm/52mm Tbs
$400 shipped - Holley 950
Car: 1992 Camaro Z28 25th Anniversary
what makes the throttle body pre 1990. will the BBK or Holley not fit on the 1992 tpi intake?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
85-88 use a stud mount throttle cable and a dedicated iac passage through the plenum. 89-92 uses a wrap around cam style throttle cable and open iac passage between throttle blade bores. 89-92 can be used on any tpi plenum because of the iac passage. Most aftermarket tbs 85-88 have this done as well.
Car: 92 1500p\u 2wd
So my engine was from a 91 Camaro but it is in my 92 c1500 truck so I guess these could be 90+ you TBS I'm pretty sure the Lingenfelter 58mm TB I have for sale is new newer version! PM me if you are interested in pics of the Holley and or Lingenfelter.....The BBK is sold
Car: 92 1500p\u 2wd
Holley commander 950 $375 shipped
Car: 92 1500p\u 2wd
Can't use it no need to have it paying around...holley commander 950 setup..... $350 shipped
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
Transmission: 700R4 2500 stall
Can u send me some photos of the holley commander and 58 mm tb or what u have my email is valencia1z@yahoo.com
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
..... I'll trade you my Pro Star wheels for your Holley Commander 950 set-up .....
Car: 92 1500p\u 2wd
Car: '87 Vette C4
I have center caps , pm me your shipping address . What harness does the C950 come with ? TPI ?
Car: 92 1500p\u 2wd
Yes TPI, I bought a used Holley Stealthram EFI swap kit a couple years ago and only used the stealthram and fuel pump.
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
Ill take the holley commander send me an email or just tex or call 2093029689 thanksQUOTE=355tpipickup;6111596]Yes TPI, I bought a used Holley Stealthram EFI swap kit a couple years ago and only used the stealthram and fuel pump.[/QUOTE]
