[ON] Third gen camaro rear end with 8.8 ford center section
Car: 1988 Camaro IROC
Axle/Gears: 3.70 Borg Warner
I am selling a 1988 camaro rear end that has the center section from a 8.8 Ford mustang. This rear end is ready to go, it will bolt right into your stock third gen
. It has Ford 9inch end bearings, a Ford motorsports carrier (from a cobra) with a 4:10 gear, the axles are 31 spline strange axles.
The Ford 8.8 is stronger than any camaro 9 or 10 bolt found in a 3rd gen camaro.
Brakes are not included.
Selling because I'm going a different direction with my build.
Make a reasonable offer. Asking $1900
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Third gen camaro rear end with 8.8 ford center section
Where are you located?
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
Hmm any idea on shipping cost to Vancouver, B.C.?
[QUOTE=caffeine;6129796]What kind of brake brackets fit on it?[/QUOTE
4th gen camaro brakes.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
What welding method did you use to weld the torque arm bracket to the pumpkin? Stick/TIG/MIG? Did you use a massive jig or have it checked for alignment? How many miles on it since this was done and is there any wear pattern on the bearings?
Car: 1988 Trans am
Engine: 305 TPI, LS1 in progress
Transmission: T-5, MN12(GTO T56) in progress
Axle/Gears: 10-bolt/308
Still for sale? Do you have answers to Tibo's questions?
