LS1 brake upgrade
Old Aug 18, 2017 | 08:48 AM
Dreambird's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 6.0l LQ4
Axle/Gears: 3.73 True Trac
LS1 brake upgrade
12" LS1 Camaro Firebird brake upgrade. Includes Power Stop cross drilled and slotted rotors, Z26 pads, Calipers, spindles, bearings, Adapter brackets, Brake lines, Bump steer adjusters and rod ends ( needs nuts and safety washers, use on my current upgrade). Very low miles used in autocross car, some wear and tear on powder coat from wheel weight rub. No issue just upgraded my brakes recently. Asking 450 obo plus shipping
Attached Thumbnails LS1 brake upgrade-20170808_135322.jpg   LS1 brake upgrade-20170808_135332.jpg   LS1 brake upgrade-20170808_135348.jpg   LS1 brake upgrade-20170808_135407.jpg   LS1 brake upgrade-20170808_135610.jpg
Old Aug 18, 2017 | 12:35 PM
stpenroute's Avatar
Car: 1989 RS Convertible
Engine: TBI 350 currently
Transmission: World Class T5
Axle/Gears: 3.73 with a Eaton TruTrac diff
Re: LS1 brake upgrade
1) For an even $400 + shipping I'll do it, but -
2) Do stock tie rod ends still fit onto the steering knuckle?
and
3) Is there a noticeable difference between these and stock?
I wanted to upgrade to the C5 or C6 brakes, but if the price is right...
Let me know when you can...
Scott
Old Aug 18, 2017 | 12:52 PM
Dreambird's Avatar
Engine: 6.0l LQ4
and
Scott
The stock tie rods will still connect to the spindles you would just need to remove the bump steer adjusters. There is definitely a big difference going from 10.5 inch brakes to 12" brakes plus the pads and rotors work very well. I will PM you on how much the shipping will be I am very busy this weekend so I will not be able to get a quote and ship them out until Tues.
Old Aug 18, 2017 | 01:43 PM
stpenroute's Avatar
Thanx brother!
Scott
Old Aug 18, 2017 | 08:34 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
Im interested in it minus the calipers if you wanna split it up. Shipping to 19078 if you want.
Old Aug 21, 2017 | 09:13 PM
Dreambird's Avatar
Engine: 6.0l LQ4
Thanx brother!
Scott
what is your shipping zip so I can get a better idea on the shipping
Old Aug 21, 2017 | 10:52 PM
stpenroute's Avatar
I'm 11743... Huntington, N.Y.
Let me know.
Scott
Old Aug 22, 2017 | 12:17 PM
Dreambird's Avatar
Engine: 6.0l LQ4
Let me know.
Scott
I PM'd you the shipping estimate. let me know if you are still interested
Old Aug 23, 2017 | 02:43 AM
1992 Trans Am's Avatar
Engine: 5.0L 305ci TPI
Transmission: 5 Speed Manual, World Class T-5
Axle/Gears: 3.08
PM'd.
Old Oct 9, 2017 | 10:27 PM
sack23's Avatar
Car: Iroc-Z
Engine: TPI 305
Thank you Dreambird. Everything came in fast, just as described.
Sac
