[FL] 350 TPI/parts
Car: 1991 Trans Am GTA
350 TPI/parts
im doing a complete swap and don’t need these parts anymore. It is a complete 350 TPI which is original to my 1991 GTA. I can sell the entire engine or part it out. There is a pinhole leak in the passenger head gasket.
- Full TPI intake system with Bosch III injectors (installed this past January). I will include the ECM and harness if needed.
- Original cast iron heads. I have not checked the casting numbers
- block with rotating assembly and oil pan, pump. Piston rings are ~60k miles on them. Done by the previous owner (ASE mechanic)
- exhaust manifolds with heat shields
- or buy the entire engine, harness and ECM complete for $400
Let me know what you need. If you want the entire engine, just the heads or short block. You must pickup in Lakeland, FL. The intake and smaller parts I can ship.
That is a red GTA plate on the throttle body
Car: 89 Firebird
Engine: 355 TBI
Re: 350 TPI/parts
Wish you weren't so far away I would ****** this up. Id love the heads and exhaust manifolds if you could ship them.
