Complete t56 swap with quality parts only 35 miles AND built chevy 350 etc
Old Jul 4, 2018 | 10:15 PM
Irockthedrag's Avatar
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
Axle/Gears: 10 bolt torsen diff 3.73
LOCATED IN 16353.. PA.
1993 lt1 t56
Centerforce conversion flywheel
Mccleod street pro clutch
Tick performance master
Gm slave
Spohn crossmember
I think i have a spare driveshaft and pedals if needed too. This is a complete swap with QUALITY parts. 35 miles on the setup, other then trans and crossmember. Trans was supposedly rebuilt, i cannot verify. 2500 OBO. I WILL NOT PULL ANYTHING UNTIL I HAVE CASH IN MY HAND.
Supposed 383 stroker, ive never pulled it apart to check. Does have torquer heads, i beleive afr rocker arms, edlebrock rpm air gap, demon 750 with mech secondaries, hooker longtubes, etc. This is based off memory alone. 1500 obo complete including accessories, carb to oil pan. Approx 30k on engine.
Serpentine setup bought from another member here, everything included. 300 obo seperate from engine
Selling as im going with a big single ls build.
Old Jul 6, 2018 | 08:47 AM
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
Re: Complete t56 swap with quality parts only 35 miles AND built chevy 350 etc
Price drop. 2300 obo on trans setup. 1300 obo on engine, 200 on serpentine setup. You cant peice together a swap this cheap. Will do 3k on the lot if you want all.
Old Jul 8, 2018 | 03:01 PM
88ricekiller's Avatar
Car: 1988 formula
Engine: 355
Transmission: five speed
Would you be interested in a f1 headunit and a little bit of cash for the setup?
Old Jul 8, 2018 | 03:54 PM
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
Not really interested in any stereo equipment, thanks.
Old Jul 8, 2018 | 05:32 PM
indy82z's Avatar
Got any more details on the engine? Block#, 2 or 4 bolt mains, etc..
Old Jul 8, 2018 | 05:52 PM
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
4 bolt main. 76. 010.
Old Jul 9, 2018 | 09:14 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I think he means F1 Procharger Head unit. As in supercharger.
Old Jul 9, 2018 | 09:20 AM
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
That makes much more sense, but im already invested in my pte setup
Old Jul 11, 2018 | 09:24 AM
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
Price drop. 1200 for complete engine 2200 fot complete trans.
Old Jul 11, 2018 | 01:08 PM
Car: 1988 formula
Engine: 355
take 2000 this weekend?
Old Jul 11, 2018 | 01:10 PM
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
For the just the trans set up?
Old Jul 11, 2018 | 01:12 PM
Car: 1988 formula
Engine: 355
Should have asked about bell housing?
Old Jul 11, 2018 | 01:49 PM
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
Trans setup is complete bell housing hydraulics flywheel clutch crossmember etc.
Old Jul 11, 2018 | 02:47 PM
Car: 1988 formula
Engine: 355
Yes for just the trans setup. What kind of bellhousing?
Old Jul 11, 2018 | 03:02 PM
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
Factory bell. Bolts right up to gen 1 and gen 2 small blocks.
Old Jul 11, 2018 | 03:16 PM
Car: 1988 formula
Engine: 355
Ok thanks. Gonna pass need scatter shield.
Old Jul 11, 2018 | 03:48 PM
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
You do realize this is a $550 flywheel, a $750 clutch, a $400 master cyl, a $150 dollar crossmember, not even counting all the other odds and ends and the trans itself? Passing because this doesnt include a scatter shield seems trivial, but thanks for your time.
Old Jul 11, 2018 | 04:48 PM
86CamaroDan's Avatar
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
Just wondering, when you say "conversion clutch" do you mean its a push style instead of the usual pull style or do you mean its the conversion flywheel?
Old Jul 11, 2018 | 04:51 PM
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
Its a centerforce conversion flywheel to adapt the trans to the old style engines. The clutch is a McLeod street pro. I dont beleive i said conversion clutch.
Old Jul 11, 2018 | 05:44 PM
Car: 1988 formula
Engine: 355
If you spent 1300 for that clutch setup you were robbed. Have the master so not needed. Passing due too seller being an *** and not worth spending money with priceless.
Old Jul 11, 2018 | 06:00 PM
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
I'm not 100% sure what you mean by "not worth spending money with priceless" but i can assure you that i have no problem not selling you this trans setup. Its priced to move and I'm sure it will. You obviously dont know much about the prices associated with quality parts, have a good day!
Old Jul 11, 2018 | 06:12 PM
Car: 1988 formula
Engine: 355
Lakewood bell spec stage three plus spec flywheel tko600 umi trans bracket and torque arm nope. Not one clue on prices.
Old Jul 11, 2018 | 07:43 PM
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
I bought this stuff over the counter at summit racing with a military discount and have receipts showing purchase amount. I dont think id put a spec anything in any car i own.
Old Jul 11, 2018 | 07:45 PM
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
If your not interested in purchasing please take your comments elsewhere. I appreciate the bumps and all but i have no interest in arguing with anyone.
Old Jul 12, 2018 | 09:29 AM
Car: 86' IROC
Axle/Gears: 3.45
Whoops. My mistake.
Old Jul 12, 2018 | 11:23 AM
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
Originally Posted by 86CamaroDan
Whoops. My mistake.
No problem! I was as confused as you were!
Old Jul 15, 2018 | 09:44 AM
LB87FORMULA's Avatar
Car: 87 Pontiac Formula
Engine: 5.7L Crate Engine
Transmission: 5spd NWC
I may be interested. Does the transmission need rebuilding? Any shift issues?
Old Jul 15, 2018 | 09:51 AM
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
Shifted fine. Has small fluid leak, unsure of where.
Old Jul 15, 2018 | 07:19 PM
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
Reduced to 2k on trans 1k on engine 150 on serp setup
Old Jul 16, 2018 | 04:01 AM
tcflint's Avatar
Car: 90' Firebird
Engine: 3.1
Axle/Gears: 3.27 9-Bolt
PM me engine pics?
Old Jul 16, 2018 | 09:33 AM
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
Not really sure how to, i couldnt get any pics attached.
Old Jul 19, 2018 | 12:18 PM
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
Trans has now been listed on ebay.
Old Jul 25, 2018 | 03:58 PM
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
Only approx 20 hrs left on my ebay auction! No reserve, currently at 1500.
Old Jul 26, 2018 | 12:33 PM
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
Had to cancel transaction with buyer. Couldnt afford the shipping. Still available, will ship. Price on trans reduced to 1900.
Old Jul 30, 2018 | 08:46 PM
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
Trans has been sold and a deposit has been put on the engine. The serpentine setup is still available.
Justin89Formy
25
Apr 23, 2014 06:20 PM
72vega
May 22, 2011 09:00 PM
89fbirdformula
Oct 4, 2010 11:29 AM
CarNDrvr
Jan 18, 2008 06:14 PM
