[ID] WTS Vortech V1 T trim cog drive bolt on kit SOLD shipped!more added!
Old Sep 7, 2018 | 09:21 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
have a 88 to 92 camaro kit polished head unit. cog drive. $1800 shipped ! will also toss in a Lingenfelter elbow (TPI throttle body to 4bbl intake)
the head unit sells for more then this.
has all bolts brakets and belts.oil lines
.with install manual. will also give you a new head unit decal (race only) to put on the unit after a brush up polish..
this is a used kit but its all there and the head unit is 100% = (no slop) smooth..lots of life left...
crank teeth pully 71 tooth head unit 35 tooth (this is off the top of my head... will check to make sure (have had it locked away for 6 years)
https://cdn.shopify.com/s/files/1/07...88182456610578
$1600 shipped!! Lower 48... any other place ill pick up $50 in your shipping
this head unit can run as much as 35lbs of boost...(with the right cog drive) just so ya know
what the elbow looks like (no TB with elbow)
Old Sep 8, 2018 | 01:52 PM
Re: WTS Vortech V1 T trim cog drive bolt on kit $1600 shipped!!
also have a full MSD BTM https://www.summitracing.com/parts/msd-6462
NIB billet MSD Distributor for the TPI cars with coil and every thing you need to plug and play.=all MSD parts needed to install.
buy the blower above and ill let you have this set up for $600 save about $300+..
ill even give you a new set of MSD plug wires (red).BALL PARK PRICE $98 ANYPLACE
this is all top shelf parts.. all new in boxes
https://www.summitracing.com/parts/msd-8227/overview/
https://www.summitracing.com/parts/msd-8366
https://www.summitracing.com/parts/msd-8876/overview/
IF IT don't sell its just going to get dusty!! sitting in a dark palce!! how sad...
Old Sep 8, 2018 | 02:28 PM
Re: WTS Vortech V1 T trim cog drive bolt on kit $1600 shipped!more added!
$8000 takes this 427sbc (this pic) show test fit..of heads and intake on short block..you bolt them on! mech roller AFR 220 heads best of everything all camp cams and AFR ..RHS polished intake 42lb injtrs..way to much to list even hooker headers..
its just going to get dusty.. give you guys a deal!!
ther is $14.000 in parts in this pic... anybody want it??
Old Sep 9, 2018 | 03:23 PM
sale pending on blower...9/9/18 SOLD
KILLER DEAL with inercoolers and blow off valves some parts not even listed..
articwhiteZ
Jan 21, 2018 08:44 PM
BlownBird
Nov 13, 2013 03:23 PM
IROCNParts
Nov 13, 2013 03:15 PM
BlownBird
Mar 24, 2002 01:53 AM
Blown406bird
Jan 5, 2002 10:12 AM
