[ID] WTS. V1T trim cog drive. polished head unit $2800 88/92 camaro
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
82 / 92 Camaro
V1 T trim Cog Drive capable of more boost than you'll eve... with polished head unit.. and instruction manual. have a couple of intercoolers also.. it is a used unit so you know it works..
will post some pictures later tonight..
$2800 plus shipping...
Steal of a deal!
and if you're interested for a little more bling also have a Chrome120Amp Alternator and brand new Chrome power steering pump with March Billet pulley. everything is set to this kit.. can add this for total Of $3000.
.. comes with belts bolts the full kit and manual..
Steal of a deal!
Re: WTS. V1T trim cog drive. polished head unit $2800 88/92 camaro
this is a bolt on and run unit...
also come with a all tubing with blow off valve..all brakets to bolt it on.and belts.and full instruction manual.. will get some more pics.
head unit needs a lite buffing..no play in shaft...set to go. this will bolt onto 88 to 92 tpi engs...
this unit V1 T Trim can put out over 30 lbs of boost with the right pullys..marked for FOR RACE ONLY!...not for the faint of heart..
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
Thats a intresting looking pulley. Mines a two piece - spacer and then a pulley. Is this specifically designed for a fbody?
come with this also... I have a full line of brand new parts from oil pan up if wanted....(for sale also)
https://cdn.shopify.com/s/files/1/07...88182456610578
Transmission: A4
How the heck does that pulley setup fit behind the radiator? That has to be really close to the upper radiator hose and fans
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
What tooth sizes for the blower pulleys and crank pulley do you have? And what width?
ill have to get pics of this set on a floor so ya can see every thing..this is a bolt on kit...BUT with a V1 T trim head unit with cog drive. and a few goodys to go with it..
will try to get pics this week...
IROCNParts
Nov 13, 2013 03:15 PM
atiroc1
23
Aug 20, 2008 12:27 AM
