1985 TPI 305 engine part out
Car: 1985 T/a, 1988 Formula
Engine: LB9 and LO3
Transmission: 700R4 and 700R4
Axle/Gears: 9 bolt 3.27, unknown
Parting out a 1985 305 TPI engine only. harness and ecm are not for sale. have older and newer air intake pieces, maf was descreened by Po. K&N air filter, air foil, i have spare parts for it as well around the garage, also have brand new napa motor mounts.
tpi is pretty much complete minus bolts, engine has around 96k miles, ran before it was pulled when i bought it. the block and the heads arent worth shipping so id rather local pick up on those. let me know what you need.
Engine: LB9 and LO3
Re: 1985 TPI 305 engine part out
if your local i would also consider trades for Pontiac engine stuff(400 block) or components, engine stand, subframe connectors for our 3rd gens, firebird pedestal rear hatch w/o 3rd brake light, t/a tail lights with center piece, 85-90 t/a fog lights.
Engine: LB9 and LO3
bump, started pulling motor, make an offer on the stuff.
oddscrounger
06-05-2019 01:16 PM
iroc_cragg
09-08-2002 01:19 AM
