[AZ] Rebuilt distributor, AC Delco and other new components
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
This is one of the stock style small cap efi distributors that I used for a while. It comes with both caps that are seen in the picture. The black cap uses the run-of-the-mill steel terminals and the grey uses the brass terminals. The rotor is also brass. The ignition control module is AC Delco. The Pickup coil is an AutoZone part. I disassembled the distributor, cleaned it, measured the shaft for wear and reshimmed the distributor gear and then put in the new AC Delco ignition control module, pickup coil, and cap and rotor about two months ago. A part from the ignition coil and distributor body, all other parts at most have a total of 300 miles of use.
Most online parts stores selling distributors are asking ~$70 and come with their crappy and unreliable ignition control module. The AC Delco module usually sells in the $60 range and I'm throwing in a spare cap.
I'm asking for $100 shipped to the 48 states. I live in the Phoenix region if you're curious about shipping costs. If you live in Phoenix I could probably meet you sometime within reason.
If you also want the MSD ignition coil you can have it for another $10.
If you want it please reply in this thread
Car: 1991 Z28 Vert
Re: Rebuilt distributor, AC Delco and other new components
Bump. Surprised this hasn't sold. I gave Thirdgen guys first dibs but time to throw it up on Craigslist also now.
Car: 1991 Z28 Vert
Still have this. $100 shipped
Car: 1991 Z28 Vert
Still available. For a little more than the cost of an AC Delco ignition control module you also get a rebuilt distributor with a spare cap. Really, don't know why this hasn't sold yet.
Mkos1980
Nov 13, 2006 06:38 PM
