Rebuild distributor?
Old Jun 4, 2010 | 07:16 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Well I'm getting closer to my car being a daily driver next thing on my list is the distributor I would like to rebuild it if it were possible the ignition control module I believe is on its way out being my car backfires under load sometimes and everything else has been replaced. Could I just put a new ignition control module, pick up, and bushing and call it a day? Or would I just be better off getting a new one?
Old Jun 4, 2010 | 07:52 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: Rebuild distributor?
really just depends on how rusty and nasty yours is. mine was pretty bad so i just bought a new one. the are only 150ish and the new ones are a better design than the stock ones.
Old Jun 4, 2010 | 09:27 PM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
In all honesty, the reluctor wheels on the stock distributors like to crack. This causes a multitude of problems. If your ignition module and pickup coil are already on their way out, just get a reman distributor. They have a redesigned reluctor that doesnt crack and better shaft bearings. It should come with a new ignition module, pickup coil, and rebuilt reluctor.
Old Jun 7, 2010 | 08:36 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
Get an AC Delco ignition module and pickup coil and follow the tread below. You will save a few bucks and learn a lot.
https://www.thirdgen.org/forums/v6/1...your-60-a.html
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
amargari
Nov 10, 2015 02:09 PM
camarohelp
Sep 22, 2015 03:19 PM
WhteRbt
Sep 21, 2015 09:48 AM
eduardosac
Sep 16, 2015 02:18 PM
