Ignition Module, aftermarket or Delco?
Old Mar 11, 2001 | 05:30 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I am thinking about replacing the iginition module in the distributor. It has been in there for 10 years now and i know stuff does not last forever. Just did a motor swap and used the same distributor.
OK, should I go with a new delco part, Accel, MSD...etc? Which one is the best and why?
Old Mar 11, 2001 | 07:51 PM
rondubbs's Avatar
i had an accel in my car, then when replacing the pickup coil i decided to put a new ac delco in,,, cant tell the difference, id go with ac delco
Old Mar 11, 2001 | 07:59 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
but how are the delco for high RPM use? like 6500-7000 rpms.
Old Mar 11, 2001 | 10:05 PM
black5.7GTA's Avatar
www.performancedidtributors.com
1990 Trans Am GTA,Black/Black Leather,350,auto 3.23,Dual Cats,SLP Package,SLP Torque Converter/Shift Kit,Fastchip,GSC's,
G-tech 0-60 5.1 1/4mile 13.6@104
Previous Thirdgen
1986 Camaro IROC-Z
Old Mar 12, 2001 | 03:49 PM
rondubbs's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Fastbird:
but how are the delco for high RPM use? like 6500-7000 rpms. </font>
im sure an aftermarket one will help out more in the higher rpms, but how often are you driving 6500-7000 rpm?
Old Mar 12, 2001 | 04:42 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
actually....every weekend. The car is for street and strip. If I put 2000 miles a year on that is a lot.
Old Mar 12, 2001 | 06:45 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I put an accel module and a hypertech coil in my 89 RS when it had the 305TBi in it. I gained about 500 more useable RPM thru all the gears. However the Accel module fried, actually burned a hole thru the top of the module! Perhaps not enough dielectric grease under the module...
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Mar 26, 2001 | 07:47 AM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
any other comments? Please people.
Old Mar 26, 2001 | 03:53 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
My Accel module failed after not even a year of street driving.
I know have an AC Delco, no problems.
I heard MSD makes a good one though.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Mar 26, 2001 | 04:28 PM
robert1's Avatar
Get one with the best warranty! NAPA sells two, a standard and better, both with a one year warranty. One's $25, the other $35.
Old Mar 26, 2001 | 05:14 PM
Natas455's Avatar
GMHTP tested the Accel module and found an average gain of 4hp and 4lb-ft across the powerband. July 2000 page 66
Old Mar 26, 2001 | 07:53 PM
GTAMAN63's Avatar
Fastbird,
I have the Accel module and have had no problems. I could not notice a difference, but 4 hp is hard to feel sop. I saved the Delco unit just in case.
Barry Izold
89 T/A, GTA
Modified 350/T-5
Old Mar 27, 2001 | 12:38 PM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
My Accel module lasted all of 3 months. I know it was installed properly. The Autozone replacement has been going for 3 years now. I really can't tell the difference.
Bob '89 Ram Air Formula 350
Last(lost)Member of the Elusive Great Lakes Crew
My car's homepage
Old Mar 27, 2001 | 06:40 PM
speeddevil's Avatar
I was thinking of going with an Accel module myself since I'm running with an Accel super coil. Is there anyone out there not having trouble with Accel modules?
pjsparts
Oct 29, 2025 06:39 PM
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
BumpaD82
Feb 26, 2016 02:57 PM
BLK87Z
Sep 18, 2015 11:29 PM
