[CA] New 300+cfm sbc aluminum heads for sale
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Selling off a project...brand new, ported/flowed pm for details
not sure what to ask....guess Ill start at 1500+ship or best offer.
If the fact these are import castings and have a pushrod pinch area epoxied doesnt bother you Id say these can make real good power for a lot less than brand name stuff with simialr #s. Im open.
Thread in eng tech section "Best heads for $1000" has some more info/pics
64cc
7/16 studs
2.02 1.6 1 pc Stainless valves
Larger dia HR springs
Straight plug
Dual intake bolt pattern
accessory holes in ends
306/240 cfm peak
64cc
7/16 studs
Straight plug
306/240 cfm peak
Axle/Gears: 4.11
Re: New 300+cfm sbc aluminum heads for sale
SF 600 bench done at QMP racing in Chatsworth Ca
4.125 bore 28"
No pipe on exh
Sheet included w/sale
4.125 bore 28"
No pipe on exh
Axle/Gears: 4.11
Im into these close to a grand with all the little stuff + work done, will listen to serious offers
If they sit around for say a month they will probably go on another block I have.
Axle/Gears: 4.11
Weekend bump, some have asked if they are American or not.
Casting is overseas, if there was something wrong with them Id have sent them back
They are a very good Dart platinum copy with lots of work done/Erson parts.
They perform as well as a 2k head just dont cost as much or have a fancy logo on them thats all.
Theres no name on the front so for all anyone knows they could be an L98 head
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
PM Sent.
Axle/Gears: 4.11
recieved pics sent. Would like to see a forum guy use em and report results...dealing with ebay/cl is a pain.
Axle/Gears: 4.11
Available for a month perhaps 2 then they are going on an engine if i have no takers.
Axle/Gears: 4.11
Due to inquiries from "covert" sellers from ebay I will not post the actual flow sheet/port stuff so noone on there gets ripped off.
Serious only please.
Sorry, too many frauds out there ruining this hobby.
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
are these 200 CC intake runners? I'm looking for some heads for 383 and S/R these are probably too much head for my needs though
Axle/Gears: 4.11
198 out of the box. I will pour them next day or so doubt they hit 210
Ports have been moved and roof raised so cross section isnt huge
Axle/Gears: 4.11
Ill quit bumping..they are what they are...but too much in this particular set to let them go for less sorry.
Can always do another
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Mischevious thoughts Would these be stupid overkill for my stock L98 rebuild if I went higher flow intake/exhaust/ .550-ish lift cam?
Axle/Gears: 4.11
Does yours use angle or straight plugs, what about the egr?
These may be overkill, a slightly smaller one may be just about right, would be less $ too. Check your pms
Engine: 350 TPI L98
Transmission: WC T5
Thanks. I probably shouldn't have posted. If I'm gonna go heads, then it will be with a stroker and hi flow TPI stuff. I'm just not there this round. Right now my 350 is a pretty good match of stock stuff kicked up just a notch. I should keep it that way.
Axle/Gears: 4.11
Lots of interest need someone who wants to buy lol
Im in these a grand....plus about 20+ hrs if that means anything.
They started at 198cc doubt if they are 205...they have had a lot of work and it shows, got a minor scuff mark here there nothing bad.
(some are picky so had to mention it)
Springs are 1.55 in 130-135 on the seat .600 lift Erson, same brand stainless valves. Guides size right etc.
Again these use a 1206 intake gasket. 1 pinch has some epoxy very clean job. Come and get em
Tootie these are probably overkill....can always do antoher would be much cheaper ..can get a 190 size also
Axle/Gears: 4.11
No longer for sale
Mods feel free to remove this thread.
