[Sold] Complete Holley Stealth Ram Setup
Old Nov 17, 2019 | 08:27 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
The last of my SBC parts, a complete Holley Stealth Ram setup. Pretty much bolt on and go setup, pulled off of my GTA last month for an LS swap. Has been installed on the car for a few years but has maybe 100 miles on it as the project really never got off the ground. Includes custom fuel lines as well, cut your stock lines down in the tunnel, install the included new Earls compression adapters and you're good to go. Everything is in good shape, some light corrosion on the TB and fuel pressure hardware, chips in paint on TB plate as pictured, but clean and presentable! $1000 plus shipping, PayPal ok or pickup in South NJ/Philly area.
Setup includes:
  • Holley Stealth Ram intake
  • Holley fuel rails with adjustable regulator
  • Accel 32lb/hr injectors
  • BBK 52mm LT1 style TB with TPS pigtail (works perfect with TPI 730 ECM)
  • Sensors: IAT, coolant temp, remote mount MAP, TPS (with pigtail), IAC
  • Braided fuel line with AN fittings and Earls hard line adapters
  • Both PCV hoses
  • All vacuum fittings installed
  • Throttle cable bracket
  • Chrome water neck
  • Liquid filled fuel pressure gauge
  • All hardware to assemble the setup including manifold to head bolts (pictured in bag)
  • Plenum and TB gaskets (gaskets are older and could stand to be replaced, but there's nothing wrong with them)
  • K&N TB Large cone filter
Old Nov 18, 2019 | 03:47 PM
Re: Complete Holley Stealth Ram Setup
Also includes k&n cone tb filter, forgot to add.
Old Nov 22, 2019 | 05:46 PM
pc0k236's Avatar
Car: 1988 Iroc
Engine: SBC 356 v8 1 turbo.Holley Dominator
Transmission: 4L80e
Axle/Gears: australian 9 bolt. 277
I am in the market for one of these. I figure I was gonna offer $800 and you would come back around a thousand. So if we could do $900 shipped to Chicago with everything I would be a buyer. Sorry about the simulated negotiations. I will do some further research to be sure this will fit on my 1st gen iron block with 90's dart heads in case we come to a deal. If not I completely understand. Thanks, Darin in Chicago
Old Dec 31, 2019 | 12:35 PM
Still available, $1000 plus shipping. Would also trade for a 1LE/or possibly other big-brake front brake setup!
Old Feb 14, 2020 | 07:18 PM
Bump.
Old Feb 17, 2020 | 05:43 AM
rgauder's Avatar
Car: 1987 Trans Am
How much without the throttle body?
Old Feb 20, 2020 | 03:19 PM
$850 plus shipping.
Old Mar 4, 2020 | 11:37 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Any takers? Is this still available
19irocz85
Jul 8, 2018 01:02 PM
3rd gen Will
19
Apr 13, 2013 09:49 PM
3rd gen Will
Feb 1, 2013 03:21 PM
darakus
Oct 19, 2009 11:25 PM
CamarosRUS
Aug 20, 2007 03:11 AM
