[Sold] Stealth Ram Setup w/ Extras (NON Vortec)
Old Jan 28, 2013 | 05:52 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Hey All,
I have a Holley Stealth Ram that I picked up off here a few months back.
Here is what the lot includes
- Stealth Ram upper and lower for standard SBC heads. it's a later casting with the inner bolt holes are drilled for 45* and 72* bolt holes.
- Holley Fuel Rails w/ crossover tube
- Kirban adjustable fuel pressure regulator
- Steel braided fuel lines with hose ends.
- 2/16" Autometer carbon fiber face fuel pressure gauge 0-100 psi
- All the -6 fitting necessary to connect the fuel pressure gauge and fuel lines from the rails, 14mm O ring and 16mm O ring to -6 to hook up to the factory hard lines.
- Thermostat housing
- Throttle cable bracket
- Factory 89-92 style TB modified to clear fuel rails with all sensors and the IAC housing (coolant tubes removed)
- Multiple barbed fitting to connect vacuum accessories, there is a T fitting under the center of the manifold that isn't pictured.
- Heater hose fitting, distributor hold down, CTS and IAT sensor included.
I am not really looking to seperate anything out. This is complete and ready to bolt on, throw your injectors in it and go. My rough guesstimate is $1000 to put everything here together new.
I'd like to get $650 Shipped in the US. I will split the shipping cost to Canada. Thanks for looking!
HSR Weiand Wieand Holly
Old Jan 31, 2013 | 02:13 PM
Re: Stealth Ram Setup w/ Extras (NON Vortec)
TTT
Old Jan 31, 2013 | 07:17 PM
inthe10s's Avatar
Stuff like this always pops up when I have no money! Don't hate me for trying......... Would you take $500 and I'll send you a UPS shipping label to use?
Old Feb 1, 2013 | 09:34 AM
I am not really in a rush to sell it, I'd go $600 if you send the shipping label.
Old Feb 1, 2013 | 10:38 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Are you open for trades? I have a TON of stuff i'm trying to part with. I also do porting. I'd be willing to port something that you might have. Look up "Endgame Performance" on Facebook for everything I have for trades and portwork if you're interested.
Old Feb 1, 2013 | 12:17 PM
Not likely, Sent you a PM though.
Old Feb 1, 2013 | 12:29 PM
Pm replied
Old Feb 1, 2013 | 12:32 PM
I also have ceramic coated 2055's with y-pipe. I forgot to mention that in the PM. I'll even throw in an Aerochamber muffler. They would work better than the edelbrock ones you have hint hint lol
Old Feb 1, 2013 | 12:34 PM
My Exhaust is set to go, thx though.
Old Feb 1, 2013 | 12:37 PM
ok cool, if you don't have it gone before I get my taxes back then i'll be all over this for my 91.
Old Feb 1, 2013 | 12:40 PM
Pm'd ya
Old Feb 1, 2013 | 03:21 PM
SOLD
Chas91Z28
Oct 22, 2015 10:12 AM
L98GTA87
Oct 19, 2015 10:43 PM
loud91rs
Oct 5, 2015 10:05 PM
evilstuie
Sep 24, 2015 02:31 AM
Liveaction
Sep 17, 2015 06:29 PM
