[NC] Lots of NIB NOS thirdgen and GM parts
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
I have a lot of Thirdgen and General GM parts for sale. Shipping and any associated fees are NOT included(paypal, etc). I have pictures of EVERYTHING, but hard to post them all here so please PM or email me for fastest response.
EMAIL IS NUFNUFFZ28@YAHOO.COM
THIRD GEN PARTS
PART PART # NOTES PRICE
Iroc center caps X8 10087754 8.5-9.5 CONDITION $40 A PIECE (THESE ARE FOR THE 1988 IROC WHEELS (AKA THE 15" Z28 WHEELS))
WATER NECK AND GASKET 14088753 NIB $50
INTAKE GASKET SET 10147994 NIB $20
CALIPER BOLT N/A $3
LAMP SOCKET 12003759 NIB $10
TRANSMISSION GOVERNOR 8640234 NIB TH250 AND TH350 $50
WIPER SWITCH ASM 26016913 NIB $15
WIPER MOTOR BRACKET N/A USED $5
STEERING PITMAN NUT 5667628 NIB $10
REAR 5 ¼ SPEAKERS X2 16163615 NIB PAIR $80 PAIR
PROM AKBW 16082173 NIB $40
ELECTRONIC SPARK
CONTROL MODULE ANUC 88261 NO BOX NEW $45
ESC MODULE HKM 882391 NIB $45
ESC MODULE ANRZ 1150003 NO BOX NEW $45
ESC MODULE ANUB 16128251 NIB $45
IGNITION MODULE 048 8C09 AC DELCO NEW IN BAG $40
IGNITION MODULE 869 6D01 NEW, NO BOX $40
GM CTS (PASSENGER HEAD) 5782 NEW, NO BOX $15
TPS 17111606 NIB $40
VACUUM FITTING 3 OUTLET 14002077 NIB $15
TEMP SENDING UNIT 8993146 NIB $20
OIL PUMP SHAFT 3998287 NIB $20
AUTO TRANS DETENT SPRING 8642247 NIB $5
P/N/BACKUP TRANS SWITCH D2207A NIB $10
115 SPEEDO NEEDLE OFF $15
AIRFILTER (OEM ) A918C NIB $20
AC BLOWER SWITCH (X2) 16068777 NIB $7.5
TIMING COVER SEAL SET 10159418 NIB $10
DIFF GEAR SPACER 12471330 NIB $5
GM CRANK SEAL 10121044 NIB $15
STEERING COLUMN SCREW 26036496 NIB X 2 $3 A PIECE
GM/VETTE PARTS
DASH VENT 1982-1990 14063264 MALIBU NIB $20
1965-1970 PS PUMP MOUNT BRACKET 3988971 NEW, NO BOX $20
*HORNS PAIR 28042 8203 & 730224 NIB $30 PAIR
GM GOOGWRENCH SHOCKS 12322202 82-83 LASABRE ELECTRA $40 PAIR
• ELECTRONIC SPARK
*ELECTRONIC SPARK
CONTROL MODULE ANRZ 1150003 NO BOX NEW $45
TPS SENSOR X2 80671/87653 USED $5 A PIECE
CORVETTE 67-82 VACUUM FIT 355786 NIB $15
*VACUUM FITTING 3 OUTLET 14002077 NIB(LOOKS SAME AS ^^ ) $15
*TEMP SENDING UNIT 8993146 NIB $20
SWAYBAR BUSHING 28-30MM 14094461 NIBX2 $5
* OIL PUMP SHAFT 3998287 NIB $20
*CTS (FRONT OF INTAKE) 25036979 NIB $15
*AUTO TRANS DETENT SPRING 8642247 NIB $5
*P/N/BACKUP TRANS SWITCH D2207A NIB $10
* TIMING COVER SEAL SET 10159418 NIB $10
* DIFF GM CRANK SEAL 10121044 NIB $15
*GEAR SPACER 12471330 NIB $5
84-96 VETTE CONSOLE LIGHT 16501169 NEW NO BOX $40
*GM CRANK SEAL 10121044 NIB $15
SPICER U JOINT STRAPS 01991 X2 0991 X1 NEW NO BOX $5
COOLING FAN MOTOR 88986474 NIB (99-05 GRAND AM) $40
AC DELCO BRAKE PADS 18024918 NIB $10
DELCO PINION BEARING 9417784 NIB X2 $20 A PIECE
DELCO BEARING 457052 NIB X2 $20 A PIECE
DELCO BEARING 7450630 NIB $20
GM U JOINT 390133 NIB (68-82 VETTE?) $25
GM DECAL(BLAZER, Yukon) 15676067 NIB $10
GM WHEEL BEARING 457196 NIB $15
GM WHEEL BEARING 457049 NIB (X2) $15 A PIECE
IGNITION CONTROL MODULE D1927A NIB $100
COIL (DELCO) D555 NIB $40
94-96 C4 FUEL RAIL HOLD 17113089 NIB $10
COOLING FAN MOTOR NOT SURE NIB $20
OIL SEAL 19221 NIB $4
GM CALIPER PISTON 179807 NIB(X2) $10 A PIECE
DELCO FP SPACER 25004553 NIB $2
THIRD GEN PARTS
CALIPER BOLT N/A $3
ELECTRONIC SPARK
GM/VETTE PARTS
• ELECTRONIC SPARK
*ELECTRONIC SPARK
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Re: Lots of NIB NOS thirdgen and GM parts
List updated.
Willing to make a great deal on large portions of the remaining parts if anyone is interested.
bwarren77
52
Sep 23, 2016 09:04 PM
BlueZee28
Oct 10, 2014 06:53 PM
6SIX6
22
Mar 18, 2011 12:53 PM
1BadGTA
Aug 17, 2006 01:57 PM
