Umi torque arm and BMR t56 transmission mount
Old Mar 16, 2020 | 10:58 PM
Bald_eagle_machine's Avatar
Car: 1988 Trans am GTA
Engine: L98 350 TPI
Axle/Gears: Factory 9 bolt w/disc brakes
BMR t56 crossmember. Fit and finish is perfect. Swapping to a different setup as this will not work with my moser 9 inch rear and tremec t56 magnum transmission. Have to switch to a body mounted torque arm. I paid $260 plus shipping. Asking $200 shipped.
Old Mar 16, 2020 | 11:01 PM
Engine: L98 350 TPI
Re: Umi torque arm and BMR t56 transmission mount
UMI brand non adjustable torque arm. Will not work with my new setup, has some minor blemishes to powdercoat. Asking $200 shipped.
Old Mar 16, 2020 | 11:07 PM
Engine: L98 350 TPI
Umi brand non adjustable panhard bar, and non adjustable LCA,s. Everything is in good shape. Powder coat may have minor blemishes but bushings are still good and the setup isnt too old. Asking $120 shipped.
Old Mar 25, 2020 | 10:50 PM
Engine: L98 350 TPI
TTT
Old Mar 26, 2020 | 08:10 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Just curious what won't work? I m putting together the same combo but haven't purchased the torque arm yet. What is the main issue you encountered?
Old Mar 26, 2020 | 01:01 PM
Engine: L98 350 TPI
it probably could be made to fit by banging on the trans tunnel, and cutting and grinding the hell out of the torque arm. But I'm not interested in all that. The torque arm needs one of the bolt hole sets cut off and you have to grind either the torque arm mount on the rear end or the inside of the torque arm to even fit on the rear. Then it's too long and hits the transmission so you have to cut it short. Figured I'd rather not butcher this one and it not work, vs just buying the other on .
Old Mar 26, 2020 | 01:06 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Interesting. I tried the same xmember and didnt like it. I have the black heart one on now and hope an adjustable TA works. Makes me ponder.
Old Mar 26, 2020 | 02:23 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
I'll take the panhard and LCA's. PM Sent
Old Mar 28, 2020 | 07:32 PM
Engine: L98 350 TPI
I just tried bolting up the new UMI t56 torque arm and it didnt fit. Do you have an aftermarket k member as well? The bmr bolts up, but the umi isnt even close. Debating the Hawks or the hooker at this point.
Old Mar 28, 2020 | 07:36 PM
Engine: L98 350 TPI
Stock GTA front sway bar. This is the big 36mm one. Biggest sway bar available. Comes with used bushings. Will need to buy your own sway bar bushing brackets. Switched to a solid mild steel variant. $120 shipped.
Old Mar 28, 2020 | 08:19 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I do have an aftermarket kmember. What's different dimensionaly from the UMI and the BMR units? I haven't purchased a torque arm yet but now I am not sure. Have you contacted midwest chassis or brute speed? They make custom torque arm mounts and cross members for fbodys with a 9".
Old Mar 28, 2020 | 08:27 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
So the BMR mount needs some messaging to fit the trans tunnel, or have I read something wrong?
I saw the Hawks mount, mercy...could make that in a few hours, sans powder coating it. I was looking at the one that was just a T56 mount though. Seemed kinda...well, just easy to make.
Old Mar 28, 2020 | 09:54 PM
Engine: L98 350 TPI
the umi unit is just a transmission crossmember. Similar to the hawks one. The mount almost looks twisted. Doesn't fit at all. I have a bmr k member. Maybe that's why the bmr crossmember fits so well? Not sure. May just keep the bmr crossmember and get a body mounted torque arm.
ShiftyCapone
LSX and LTX Parts
Jul 30, 2020 03:09 PM
white85transam
Oct 1, 2019 07:53 PM
cal30_sniper
Mar 5, 2012 10:10 AM
84TA400
Dec 4, 2011 08:16 PM
SnkSknrZ28
May 7, 2008 06:05 AM
