[FL] Lingenfelter 58mm Throttle Body 85-88
Old 04-08-2020, 10:47 AM
C409's Avatar
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
….. SOLD … Lightly used Lingenfelter 58mm TB with TPS and NEW IAC … $275.00 shipped to the lower 48 …..
Old 04-12-2020, 11:25 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Re: Lingenfelter 58mm Throttle Body 85-88
Does this bolt up to a factory motor?
Old 04-12-2020, 12:31 PM
C409's Avatar
Car: '87 Vette C4
….. It will bolt on to 1985-88 Tuned Port Injection manifolds , TPIS Mini-Ram , Stealth Ram , and others that may have slipped my memory … This throttle body may be overkill on stock-ish engines …..
Old 04-29-2020, 07:27 AM
C409's Avatar
Car: '87 Vette C4
Old 04-29-2020, 09:37 AM
Engine: 350 TPI L98
Transmission: WC T5
I have an 89 so my throttle cable end is different. Do you know if I can swap the throttle arm from my factory 89 TB? Just trying to avoid swapping the cable.
Old 04-29-2020, 11:47 AM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
@Tootie Pang The other one you asked about has the 89-92 linkage but missing this air inlet. Theback of the tb has the bored connected not all tbs do. Will work if you swap throttle cable
Old 04-29-2020, 01:09 PM
C409's Avatar
Car: '87 Vette C4
….. I honestly don't know if the stock throttle arm would fit … as you can see in the pics , the Lingenfelter arm bolts on … perhaps someone @ Lingenfelter can provide you with more accurate info , and possibly the correct bellcrank style arm to fit your '89 cable …..
Old 04-29-2020, 05:40 PM
Drew's Avatar
Received 1,052 Likes on 748 Posts
Easier way to go is to change the throttle cable.
zman1969
07-15-2020 10:11 AM
BHR
02-09-2020 07:09 PM
kawaslut
12-27-2019 11:04 AM
zman1969
07-01-2019 08:27 AM
Quick Reply: [FL] Lingenfelter 58mm Throttle Body 85-88
