[NC] Serp bracket and engine misc
Old Jun 10, 2025 | 03:21 PM
Pocket's Avatar
Car: 91 Trans Am
Minor stuff taken off my 91 TA
PS serp bracket with tensioner. Bracket has been sand blasted. Just have the PS side
$75 shipped
Make an offer on the rest. I'll be throwing it all away in 3 months
Heater core tube that runs down the frame rail
Semi-new heater core bypass valve
AC hardline. I see people ask about this semi regularly. The front nut is sized to the tube, so it needs some work to be 100% - SOLD
Coil, bracket and EGR solenoid. Old but work, EGR solenoid isn't available new these days, so used is the only option
Original distributor, 137k miles, new cap, rotor, IGN module. One screw broke off in the base. That side is zip tied closed
New set of plug wires, new retainer clips and repaired manifold heat shields
Smog pump - SOLD
Smog bracket, divider, tubes etc
Old Jun 10, 2025 | 05:32 PM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Re: Serp bracket and engine misc
I'm interested in the AC liquid line. What's a fair price to you? Message me please. My zip code is 34677 if you could get a quote for shipping as well.
Old Jun 10, 2025 | 05:40 PM
Pocket's Avatar
Car: 91 Trans Am
Hows $75 shipped? The box is going to be the bulk of it
Old Jun 11, 2025 | 08:11 PM
bennettcvcu's Avatar
Car: 1988 IROC-Z
Engine: L03 to L05: 350 TBI
Transmission: MD8: 700R4
Axle/Gears: GU2: 10 bolt/2.73
How much for the dizzy? what type of cap, rotor and ICM does it have?
Old Jun 11, 2025 | 08:50 PM
Pocket's Avatar
Car: 91 Trans Am
$65 shipped
Standard motor co parts. I've had good luck with them on DD vehicles
Keep in mind it has a broken screw in the dist base. A zip tie hold the cap closed on that side
Old Jun 11, 2025 | 11:30 PM
Drgnbld's Avatar
Car: 89 GTA
Transmission: auto
Axle/Gears: 3.23 BW 9 bolt
What are you using in place of the heater core tube? I'm looking for different ideas in place of mine.
Old Jun 12, 2025 | 08:01 PM
Pocket's Avatar
Car: 91 Trans Am
90* 5/8 hose intake to HC
Generic 3/4" hose HC to radiator
Pretty basic
NullHead
Jul 27, 2013 10:53 AM
heartattack
Oct 31, 2012 08:41 AM
TigerVette
Jul 2, 2012 09:42 AM
ProChrgdTa
May 4, 2003 08:43 PM
TransAmTBI
Jan 27, 2003 10:54 PM
