Need Help - Problems w/ Aftermarket TPI Base
Old Jun 2, 2009 | 01:56 PM
TigerVette's Avatar
Two Problems I've come across and trying to match my hardware to it.
First off, the red arrow points to a hole next to the egr block off. What goes here? I did not have this on the stock manifold. Just plug it?
Second, there's a bracket that goes between the two blue points through the manifold bolts. The aftermarket manifold has a raised bump in between which doesn't allow the bracket to set flat. Best to buy extended bolts to bolt on top of then? I'd hate to deal with cutting or dremeling... Appreciate any advice!
Old Jun 2, 2009 | 02:05 PM
Guest
Guest
Posts: n/a
Re: Need Help - Problems w/ Aftermarket TPI Base
Red Arrow- Pretty sure that goes into the coolant port. Definitely plug that and forget it. Might be best to use a recessed allen head plug in that spot.
Bracket- No clue. Any way you can grind the bracket base to clear it?
Old Jun 2, 2009 | 02:25 PM
TigerVette's Avatar
The bracket would need to have a big chunk cut out, would rather use longer bolts and put the bracket on top. Just curious if anyone else had run into this.
Old Jun 2, 2009 | 10:02 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Like the others said, you can just use a plug in that small hole.
For the coil/EGR solenoid bracket, you can use washers to stand off the bracket. When I installed my Edelbrock years ago, I went and cut the center portion of the bracket out. Looked much cleaner.
I might have even used a hardened flat washer at each bolt under the bracket too. It was a long time ago........
Old Jun 2, 2009 | 11:23 PM
MaxpowerTA's Avatar
Car: 1992 T/A convertible
Engine: LB9 TFS175heads Ebase/accel runners
Transmission: T5 5spd
Axle/Gears: 4.11
I just installed one of these last week, i cut the middle out of my bracket and it sits right where it's supposed to now. As for the hole i just thought it was an empty bolt hole(didnt look at it too closely), I guess i will plug it too
Old Jun 2, 2009 | 11:47 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
agree with last post just dremel the bracket to make it fit simple fix
Old Jun 3, 2009 | 04:34 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Plug and cut.
Old Jun 3, 2009 | 12:08 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
I use the coolant port as a high point air bleed using a radiator drain valve.
I didn't have a bracket, previous owner must have removed it (EGR Solenoid bracket?)
Old Jun 3, 2009 | 12:13 PM
Guest
Guest
Posts: n/a
One some cars, others have the coil bracket there as well.
Old Jun 3, 2009 | 12:42 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Explains the coil's short harness; I couldn't use it anyway with the extenal EGR tube, and tall alum valve cover taking up that space.
Old Jun 3, 2009 | 01:16 PM
TigerVette's Avatar
Hey everyone, thanks for your input.
Fortunately I didn't have to cut or grind a thing. A member on another site said using slightly longer bolts and some washers helped him clear the manifold bump. Worked great and actually the bracket bent enough to mold to the bump, so it's a nice tight fit.
and my left over hardware filled the steam hole and tightened the distributor hold-down.
Old Jun 4, 2009 | 12:14 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
That "steam hole" tees into the heater core line on a vette.
Old Jul 2, 2012 | 09:00 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Anybody know the size of the hole that needs to be plugged (red arrow). I'm installing the Eddy Hi-Flo manifold also.
There's also a third hole in the front that wasn't on the OEM manifold, what should be done there....plug?
And if so what size??
Thanks,
Old Jul 2, 2012 | 09:42 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
They are the same as the cold start switch and Coolant Temp Sensor, 3/8" npt I believe.
InfernalVortex
Apr 20, 2021 11:31 AM
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
bjpotter
Oct 4, 2015 07:48 PM
Luigytico09
Oct 1, 2015 08:46 AM
