3.42 3.73 rear end wanted
Old Jun 29, 2006 | 01:43 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
i want a 3.42 or 3.73 geared rear. if it has disc brakes it must be posi but if it has drums then it can be an open diff. must be in good working condition and come with calipers.
Old Jun 29, 2006 | 04:50 PM
tpi-hearse's Avatar
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
got a 3:73 posi disc out of a 1984 z-28 h o $300
Old Jun 29, 2006 | 10:04 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Buyer not interested in my set-up
Old Jun 30, 2006 | 12:01 AM
Engine: LO3
tpi hearse what does it come with? ebrake cables, lines, prop valve?
Old Jun 30, 2006 | 01:09 AM
tpi-hearse's Avatar
It is complete disc to disc..no ebrake cables(they were junk like most)..I can give you a disc proportion valve if you need it....
Old Jun 30, 2006 | 07:23 PM
Engine: LO3
whats mileage and does the posi still work?
Old Jun 30, 2006 | 08:13 PM
drptop70ss's Avatar
Car: way too many
Engine: 283s to 454s
Transmission: autos and sticks
I have a complete drum to drum 3:23 9 bolt posi rear, posi works fine, currently in an 89 GTA. Comes complete and has recently replaced rotors and calipers, $300, I am in NY zip 12538, about 45 minutes from danbury. Brake booster and prop valve included.
Old Jul 1, 2006 | 12:11 AM
Engine: LO3
is your 9 bolt a drum because you said drum to drum
Old Jul 1, 2006 | 06:46 AM
drptop70ss's Avatar
Car: way too many
sorry just used to typing that it is a disc rear, so complete end to end .
Old Jul 1, 2006 | 11:50 AM
Engine: LO3
anybody want to give me any mileage on these?
Old Jul 1, 2006 | 12:54 PM
John in RI's Avatar
Old Jul 1, 2006 | 01:49 PM
drptop70ss's Avatar
Car: way too many
Odometer reads 117K on mine.
Old Jul 1, 2006 | 01:51 PM
smithj_2006's Avatar
Car: firebird
Engine: 350 olds
Transmission: 350 olds
i have a complete 9 bolt rear end with disc brakes set up for an f-body if you want it. pm me and well talk dollars and cents if your interested.
Old Jul 1, 2006 | 08:18 PM
tpi-hearse's Avatar
94,000 on the odometer.......
Old Jul 2, 2006 | 12:27 AM
Engine: LO3
ok tpi hearse let me talk it over with my father if he oks it then well work something out about getting it since i know your in mass i believe and im in CT i dunno if youd deliver id give you some extra if you did but if not ill work on something
Old Jul 2, 2006 | 12:44 AM
tpi-hearse's Avatar
I am in East Windsor Ct..
Old Jul 3, 2006 | 12:14 AM
Engine: LO3
ok sorry wrong person then hmm yea ill def think about it talk it over with the pops whos gets the final say and if so id have him go with me to get it with his truck.
Old Jul 5, 2006 | 11:22 AM
Swim500in5's Avatar
Car: 83 Z-28
Engine: 305 Qjet
Transmission: 700r-4
ive got a 3.73 41/11 with drum brakes in rochester ny. make offer
Old Jul 5, 2006 | 09:37 PM
Engine: LO3
whats the 41/11? and is it posi or open diff? miles?
Old Jul 6, 2006 | 06:30 AM
Swim500in5's Avatar
Car: 83 Z-28
Engine: 305 Qjet
41/11 and 41/12
they are the gear ratios. 41 is the number of teeth on the gear and 11 is the number of teeth in the input gear. 41/11 = 3.73 41/12 = 3.42 as far as miles the gears look great i have no idea when they were actually replaced. if i had a use for them id keep them. as for posi i forget how to check. when i spin the drive shaft end. only one wheel moves. i believe that means they are open. not sure how to check
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
