350 heads 60-64 cc
Car: 92 Camaro RS
Engine: 350 .030 over compcam 12-212-2
Transmission: T350
Axle/Gears: Borg/Warner 9 bolt 3.70
350 heads 60-64 cc
Looking for a good set of 350 heads to fit a 1986 350 4 bolt main. Would like to find them within a 50 mile radius of Albany GA.
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
I have a set of 305 heads with a 416 casting, 58cc chamber i believe. Great condition, complete.
Car: 1984 Z-28
Engine: 350(bored 0.060)
Transmission: Probuilt TH700-r4 tranny with the w
Axle/Gears: 10 bolt 7.5" posi 3.42
Did you still need a set of heads? I have a set of 081 castings and Im in Warner Robins.
Car: 85 Camaro IROC-Z
Engine: Dual Snorkel 350 Carb
Are you putting those 416's right on to your 350? Or are you going to do some work to them first? I am wondering how the 1.84 / 1.50 valves will perform in a 350.
I have a set of 416's from my old 305 that I want to use on my 350, and want to know if I should change the valves to 1.94 / 1.6 first.
Car: 1984 Z-28
If you put 416s on your engine, it would be wise to do some home porting, bowl blending, and increase the size of the valves to 1.94/1.6. Also, you can buy a $20 tool from summit racing to take out the pressed in studs, and line up a tap for the screw-in type (worth more hp in terms of higher lift). For tips on porting, look up Sitting Bull on this website, or go to: Standard Abrasives, Inc.- www.standardabrasives.com - Manufacturer of coated abrasive specialties and BriteRite non-woven abrasive products for industry. Site includes full listing of products, distributor search and educational material. Standard Abrasives Motor Sports, Inc.- www.sa-motorsports.com - Motor Sports site featuring high-performance abrasives for the mechanic and the auto enthusiast. Includes tech tips and FAQ's and distributor search.
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
