'88 350 ESC, PROM, Injectors needed
as stated I need:
'88 350 ESC Module
'88 350 PROM
Injectors for a 350
Valve covers for older Perimeter bolt on covers
Also could use headers/y-pipe/catback for my '88 trans am
headers/y-pipe
catback
350 knock sensor
emissions not required.
I'm in the middle of swapping my '88 trans am from 305 TPI to 350 TPI. I have a jasper crate engine going in, located a 85-86 LIM to make it work, I still need larger injectors and all the above for it to run properly. The exhaust on it is rusting off, and currently ends after the cat due to rust.
Obviously I'm ditching the smog pump, and don't just want to plug the holes in the manifolds, would rather remove all together.
Trying to just fix this beast on the cheap. Have a $500 budget, and have spent $125 so far for the motor.
'88 350 ESC Module
'88 350 PROM
Injectors for a 350
headers/y-pipe
catback
350 knock sensor
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I have a 88 firebird 350 tpi chip, your 86 tpi ecm is the same if I am reading this right and the 86 came with tpi
Engine: ls1, LB9
well, I guess I never knew that. I just know the knock sensor and memcal injectors are differant. anyway what I have and do know is I have a almost new memcal # AKXY 16083286
Engine: ls1, LB9
