Need injectors for '91 350 TPI
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
Looking for replacement 22# injectors for my 91, with low mileage if possible.. Will also consider FMS 24# injectors..
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Did you see this thread yet, https://www.thirdgen.org/forums/engi...injectors.html?
Those are the same injectors that you already have. It would be better to find some earlier Bosch or Rochester 22# injectors.
Yeah I had seen it but I figured I couldnt send those in to Cruzin Performance since they are probably the Multec's and he won't work on those.. Figured I'd get a different brand since they are said to be high failure rate..
