350 main caps
Old Feb 11, 2007 | 09:20 AM
speedemon75's Avatar
Car: 84 Firebird
Engine: 2.8-hampster
350 main caps
I'm looking for a set of one piece rear seal main caps for a 87 350 block. Also a good used oil pan for the same 350.
Old Feb 11, 2007 | 09:29 AM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
2 bolt, 4 bolt? You know 305 caps will work. You also know you cant just replace the caps, its going to be align honed right?
Old Feb 11, 2007 | 09:45 AM
Car: 84 Firebird
I thought all 87-93 blocks were 2 bolt, anyways it is a 2 bolt. You are right the 305's will fit but they are not a direct fit since the 305's use a smaller main. The mains will be align bored.
Old Feb 11, 2007 | 11:09 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, they don't.
Old Feb 12, 2007 | 06:11 PM
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Nope your wrong on both. Some of the truck blocks are a 4 bolt main. 305 and 350 mains are the same. You can take a crank out of a 350 and slap it in a 305. Stroke is the same, mains are the same, and rods are the same.
Old Feb 12, 2007 | 06:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, but also despite having the same stroke, 305s and 350s use different cranks.
Old Feb 12, 2007 | 08:37 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
either way, i've got a set of stock 305 main caps, say 20 shipped? PM me
Old Feb 15, 2007 | 03:10 PM
LT1Formula's Avatar
I have the main caps and the oil pan. $60 plus shipping. Bill
Old Feb 17, 2007 | 11:44 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I can do 50 plus shipping for caps/oilpan from 95361.
PM me if you still need them.
Old Feb 17, 2007 | 02:37 PM
MartinD's Avatar
cranks are the same on 305/350. here is an example from www.mortec.com on a one piece rear seal crank
14088526...305,350...cast....medium journal...3.48" stroke
and two piece seal
3932442..267,305,350..cast...medium journal...3.48" stroke
Old Feb 18, 2007 | 01:20 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The castings are the same. The finished cranks are different.
Old Feb 18, 2007 | 06:32 AM
MartinD's Avatar
We used in both and never had any problems.What are the finishing diff.?
Old Feb 18, 2007 | 12:50 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The machining of the counterweights is different. The 350 has more mass left on to balance the heavier rotating assembly. You can tell the difference by laying a straightedge along the counterweights. The 305 crank will allow the straightedge to sit flat as shown in the picture.
Infested
May 22, 2018 11:56 PM
Eric-86sc
Aug 24, 2015 09:01 PM
Out-Cast
Aug 17, 2015 10:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
