V8 crossmember needed for 92 camaro
Car: 1992 Camaro RS
Transmission: T5- manual five speed
hello i need a V8 crossmember for a 92 camaro with a 350. Please email at drjczach@gawab.com. thank you
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
I have been told it's the same as a V6's. I would check before purchasing if your going from 6 to 8.
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
I have one too. If you have not already purchased one. Mine has new bushings.
Car: 1992 Camaro RS
hey sorry for not responding sooner but the board wouldnt let me due to email problems, BTW email is drjczach@gawab.com not jmaster@ix.netcom.com.
how do you find out if the trans crossmembers are the same or not in a v6 or 8?
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
It's the same......
Chevy used 2 versions of the cross member; a 1 piece and a 2 piece design. Either style can be used with a V8 or a V6. The 2 piece has Rubber bushings that transfer a little less vibration to the body than the 1 piece design.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
