Wanted TH-400, or TH-350
Old Mar 14, 2007 | 12:20 AM
BBCAM's Avatar
Car: 99 Camaro
Engine: LS
Transmission: TH-400
Axle/Gears: 3.25 9"
Hi, Im in need of a transmission for my Pro Street T/A
I have a few trans around but they all need rebuilds at this time and my guy that usually does them is out of commission and I havent had any luck finding anyone who can do one for the cash I have on hand, (I had surgery in feb so im kinda strapped for cash )
So im looking for a usuable TH-400 or possibly a TH-350 (the car had a 400 and I have all the parts to put one back in) but I can make a 350 work if thats all I can find ..
I have $300.00 to spend and can arrange pick up if within 100mi of Janesville Wi
I just need a stock trans no converter (I have some) that will bolt in with a minimum of hassle,
a kitted one would be nice but I just need to get this on the road
let me know what you have and Thanks ! BBCAM.
Old Mar 14, 2007 | 06:20 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i have a good running 3L80HD from an 87 it is a 400 case but 27 spline like a 350 and 700r4 etc
it is 34.5" long overall thats 3" longer than a 700r4
tag code LJA 87
runs good,
make offer if you have a way to get down i-55 to central IL exit 123
or ?
good luck
Old Mar 14, 2007 | 10:26 PM
BBCAM's Avatar
Car: 99 Camaro
Engine: LS
Axle/Gears: 3.25 9"
Im thinking that would be a little more work than putting a standard 400/350 in .. if it's longer than a 700r4 I may not have enough room (my car is framed and tubbed) and the crossmember is set for a standard length (short 400 case) thanks though...
Old Nov 1, 2007 | 10:40 PM
drnapski's Avatar
Car: 89 Iroc Vert
Re: Wanted TH-400, or TH-350
Have TH-350 w/ manual valve body from 88 Formula.
Old Nov 2, 2007 | 11:58 AM
j dezzy's Avatar
Car: 87 TA
Iv'e got a turbo 350 that was in my fiance's olds. It's got less than 500 miles on it after it was rebuilt. you'd just need a tailshaft housing for it. the one on it now doesn't have a mounting spot for your torque arm.
Old Nov 2, 2007 | 12:34 PM
rob1971's Avatar
If it's out of an OLDS with an OLDS engine the bolt patter won't work.
Old Nov 2, 2007 | 01:24 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
i've got a th350 with less than1500 miles on since rebuilt.$100.located in pekin,illinois
Old Nov 2, 2007 | 03:00 PM
Fast3rdGen's Avatar
Too bad, I am seling my TCI TH400 and 3500 converter. I'm in Ohio.
Old Nov 2, 2007 | 04:01 PM
j dezzy's Avatar
Car: 87 TA
It's not an olds trans. I did a chevy conversion on the car about 2 years ago.
Old Nov 3, 2007 | 12:00 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
I have one I built a couple years ago when I was foot brakeing. It has a trasgo shift kit in it, and high gear has an extra disc and plate in it. I ran it behind a 600 hp sbc in a 3000 lb bird. In D it shifts at 5200/5300 or can be manual shifted. It'll go in any gear at any speed when shifted manually. But I need 350.00 for it. Just down 55 to Springfield, ILL. Live about 1 1/5 miles off of the interstate. E-mail me in interested. Charles.
Old Jan 16, 2008 | 09:01 AM
86blueiroc's Avatar
Car: 1986 IROC-Z
are you still looking for a TH350, I have a great one with 750 miles on the rebuild?
Old Jan 16, 2008 | 11:53 AM
BBCAM's Avatar
Car: 99 Camaro
Engine: LS
Axle/Gears: 3.25 9"
Thanks for the replys, just so everyone knows the car has been done and since sold due to financial issues But Thanks !
gta90
Sep 15, 2015 04:00 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
E Rod
Aug 28, 2015 05:17 AM
Logan Bryant
Aug 27, 2015 11:52 AM
86White_T/A305
Aug 17, 2015 12:16 AM
