Wanted L98 350 TPI
Car: 1972 GMC
Engine: 355
Axle/Gears: 4:10
Wanted L98 350 TPI
The friend of mine that wanted the 305 now has decided to go for a 350 so what’s out there, he wants his car back on the road. He would like a 87 or newer (one piece rear seal and roller cam) complete engine TPI would be best.
John
John
Car: 86 Iroc-Z
Engine: 310ci soon to be 355ci
Transmission: built 700r4
Axle/Gears: I think 3.08s
Re: Wanted L98 350 TPI
i got a rebuilt 355ci one peice rear main seal. Center bolt heads rebuilt also. It has a Carb set up not but its a Fuel injected block. Less then 10mi on motor. Cam has been broken in also
Car: 1972 GMC
Engine: 355
Axle/Gears: 4:10
Were are the specs, were are you located and what are you looking to get for it.
John
John
Car: 86 Iroc-Z
I live in Pa, Specs not to sure of but i believe its a roller cam, Its a 86 and up 2blt main FI Block, Has rebuilt 193 casting heads center bolt vortech. Has a carb set up but not the right set up. I have the numbers somewhere on the block and heads. Block was made in canada. Its all stock exept for the cylinders. EVerything is new.
Sanjay
Aug 12, 2015 03:41 PM
