TPI TV/Kickdown cable needed
Old Apr 17, 2007 | 04:50 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I need a TV cable from a 1985-88 3rd gen, TPI only. 4bbl carb and TBI TV cables are totally different length and will not work. 89+ definitely used a different throttle cable, and may use a different TV so I am not sure on those years.
Old Apr 17, 2007 | 08:21 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Re: TPI TV/Kickdown cable needed
How do they come off the tranny? Never removed one before. I have an 86 tranny lying around.
Old Apr 18, 2007 | 07:23 AM
Car: 2000 BMW M5
Unbolt the one little bolt that holds the plastic cable end to the transmission, and remove. To remove the metal inner cable from the trans, pull up, then you will see it is hooked on a metal thing, and slide it off. A needle nose pliers will probably help. Let me know.
Old Apr 18, 2007 | 07:04 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Sounds easy enough. How much should I charge you for it? I can pull it this weekend(or sooner). LMK. Dean
Old Apr 19, 2007 | 09:23 AM
Car: 2000 BMW M5
$15 plus shipping. They are only around $20-25 new but I am too busy this week to go drive out to an Autozone, since Advance can't get it.
IROCZ1989
Jan 24, 2016 03:55 PM
fonzie85
Aug 13, 2015 11:50 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
