Wanted 21 Driven gear for speedo
Old Apr 22, 2007 | 10:29 PM
guitarboy350's Avatar
Car: 86 Z28 Camaro
Engine: 305 4bbl
Hey there, I'm looking for a 21 tooth driven speedometer gear for my t5. It would have to have the metal shaft with the plastic gear at the end. It's for my 86 Camaro if you can help me please reply. Thanks Richie
Old Apr 23, 2007 | 09:52 AM
f1ls1's Avatar
Car: 1999 F-1 Camaro Conv 1990 Iroc-Z
Engine: LS1/L98
Transmission: A4/A4
Axle/Gears: 3.23/3.27
Re: Wanted 21 Driven gear for speedo
Try this place. Bottom of the page is the T5 stuff.
http://www.transmissioncenter.net/sp...n_______va.htm
Old Apr 28, 2007 | 08:29 AM
Car: 86 Z28 Camaro
Engine: 305 4bbl
Yea, I did checked out that site before and moderndriveline.com to see if they had the gear that I am looking for. They have every gear except the one I am looking for lol
Old Apr 28, 2007 | 09:11 AM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
did you try www.tciauto.com?
Old Apr 28, 2007 | 09:19 AM
f1ls1's Avatar
Engine: LS1/L98
Transmission: A4/A4
If you have the part number you can check with this company.
https://www.vintageparts.org/
They buy up all of GM's discontinued parts. You can type the part number in their loctor and it will tell you if they have it and how many they have.I brought a lot of the parts I used to restore my car from them.
Old May 2, 2007 | 04:34 PM
Car: 86 Z28 Camaro
Engine: 305 4bbl
Thanks for the help but still coming up empty handed
Old May 2, 2007 | 05:07 PM
f1ls1's Avatar
Engine: LS1/L98
Transmission: A4/A4
Have you tried getting the dealer to do a parts locate for you?
How about these guys.
http://www.5speeds.com/t5/index.html
http://www.safepay.net/cgi-bin/shop/...oderndriveline
Old May 2, 2007 | 05:28 PM
Car: 86 Z28 Camaro
Engine: 305 4bbl
Yea, I did that awhile ago. I work at a dealership and I had someone checked to see if any dealership has the speedometer gear in their inventory. He also called up a couple of transmission shops to see if they had any laying around but thanks for your help.
Old May 10, 2007 | 07:21 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
you need to make one like I did. i had the same problem as you. I even contacted a few t-5 rebuilding places thinking they might have one from a pull out.. no luck
Jeremys87
Jul 14, 2022 09:08 PM
customblackbird
Aug 15, 2021 10:16 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
mizz0313
Aug 12, 2015 06:45 AM
beachrodder
Aug 7, 2015 04:27 PM
