wtb complete tbi intake
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
as stated,I need one.Putting it on my old 305 I took out of my iroc and dropping it in my truck when the 4.3 gives out.Lets talk prices.I`m not exactly ready to buy just seeing what Its gonna cost if I can find one.Thanks
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
Re: wtb complete tbi intake
ill have the whole tbi set up as soon as i get mine pulled and swap the carb parts into my 89 maro. i just need an intake and some fittings and brackets and i should be ready to do the swap
Car: 87 IROC Z
Engine: 5.7 L98 TPI
What year?It should bolt right up to a lb9 huh?What you want for it?
Car: Camaro RS
Engine: 305 tbi
its off of my 89 rs 305 lo3 5 speed, not sure how much i want for it, actually if you could locate an intake for me and some small misc. stuff for a carb swap i will be glad to trade you. i know that the tbi set up is worth well more than just an intake but heh, what the H:E:L:L do i need it for right
Car: 87 IROC Z
Engine: 5.7 L98 TPI
I`ll try but most all my stuff is for tpi.I know ebay has a bunch of stuff,I just saw the carb stuff on there looking for a tbi intake.What all do you need?What kinda intake you looking for.Paceperformance.com has a bunch and so does jegs,summit.I dont really know anybody with any just sitting around.
Car: Camaro RS
Engine: 305 tbi
well you said you not quite ready to buy yet anyway so you have time to look. i am just looking for a performance intake to do my carb swap such as an edel, performer, or something along those lines.
Car: Camaro RS
Engine: 305 tbi
IM TELLIN YA> an entire tbi setup including tbi, tbi intake, ecm, wiring harness, and whatever else is worth WELL over what an intake is worth. i can also throw in the maifolds w/o air if you want
Car: 87 IROC Z
Engine: 5.7 L98 TPI
I`M pretty sure I can use all the 4.3 tbi stuff for the 305 other than the eprom or whatever it has.The ecm is the same from what I`ve been told.So is the tb and injectors.Since the 4.3 is a 350 with 2 cylinders missing most stuff should work.I just need an intake with 2 extra cylinders and maybe a few other things.I`m also putting some lt`s on my iroc soon and I`m gonna try and see if the flowtechs will fit the truck.and I do have the stock manifolds.Air is easy to remove.I guess I shouldnt have said I need an entire set up.I would take one for the right price but I think I can make it work with the intake and maybe the e prom.I thought I could find a couple dozen people with these things lying around fairly cheap.I`m sure theres a few hundred thousand in junkyards around here.
Car: Camaro RS
Engine: 305 tbi
well i also need a front nose cover for my rs so whatever you can do if ya cant do it then just let me know
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
If you're interested, I have a TBI intake that's been bored to accept the 454 throttle body unit. I also have the throttle body and extra spacer. I can throw in some gaskets too.
Let me know.
Lou
Let me know.
Lou
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Thats not going to be too much for a 305 with a mild cam and a little headwork.I`m not going for power here.Torque orriented engine for my 4x4 truck.Its the lb9 I took out of my Iroc.That seems like it may be a lot of air for lil 305.What do you think?how much you want for it?I`m not looking to spend much money on this thing.
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
I have a stock intake and throttle body off a 1992 firebird if interested $75 shipped
Engine: TPI
Just thinking aloud here: if you're doing head work and adding a mild cam, you won't benefit much from it unless you supply more air. The 454 TB is considerably wider which would comlement the headwork nicely. I thought $150 could do it. I'm not in it for the money, just need to cover my original cost.
Lou
Lou
Car: 87 IROC Z
Engine: 5.7 L98 TPI
That makes perfectly good senseI was just thinking 305....454....lil bit of difference there.Price sounds great for what you got there.Biggest prob is I just bought a house and I`m still moveing in.Broke aint the word for it.Be a week or two before I`ll have any extra money.BTW,what size injectoes would that call for?Would the stock ones be adequate?What about tuneing?I would need a tune anyhow with a cam swap so anyway.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
mani just took an 87 TBI intake to the scrapper a few days ago for aluminum
was tiredof looking at it around here and posted it for mail cost on here a million times
hum
thats how it goes i guess
good luck
hum
good luck
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Tup,thats how it goes.I figured somwone had one lying around they had no use for.I like that one ready for the 454.Just poor at the moment
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
I have a stock TBI manifold with the throttle body and injectors if your still looking, it will need a TPS though and a cleaning. Let me know and i can get you some pictures
Terrell351
Jun 13, 2021 01:13 PM
TA8487
Aug 16, 2015 12:21 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
