Wanted: SFC's and tubular K Member
Car: 1992 GTA
Axle/Gears: 4.10
As the title states, I am looking for some subframe connectors and a tubular k member.
K member can be set up for stock SBC mounts or LS1 mounts. I can make either work as I already have a set of Spohn LS1 conversion mounts.
I prefer a weld in type SFC, but I have welded up the bolt in type as well and they can work depending on the manufacturer.
Let me know what you have and how much.
Re: Wanted: SFC's and tubular K Member
i have a new set of bolt on sfc. form comp engineering. still in box. make an offer before i put them on ebay on monday.
thanks
danziroc383@yahoo.com
thanks
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: 5 Speed
Axle/Gears: Ford 9"(Moser),4:11s,locker,31splin
What kind and where are you located,I am in Canada,will you ship how much ware you asking?
Car: 1992 GTA
Axle/Gears: 4.10
Car: 84 Trans Am
Engine: 383 Stroker
Sorry was not tring to hijack the thread,late night with very little sleep means I make dumba** post.Was not tring to be an a** didnt even relize which section I was in,good luck in the sale.
Later DEL
Later DEL
Car: 1992 GTA
Axle/Gears: 4.10
No problem, smallblockking never did reply to my question. To be honest I have already had the Comp 3120's. Even tho they are a bolt-in SFC they need to be welded in. That and if you do decide to just bolt em in, you need to drill holes through the floorpan of your car.
I love the UMI weld in SFC's. They are a very good piece for under 200 dollars and they join in the front subframes with the SFC's. Stuff like the Comp bolt ins do not. That makes a pretty big difference considering it doesn't cost much more at all. Spohn has these same brackets as UMI but I have never used Spohn yet. I like square tube design over round tube like Spohn stuff. Just my opinion tho.....
Pac J
May 17, 2020 10:44 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
LT1Formula
Oct 8, 2015 08:34 PM
