WTB miscellaneous T5 parts
Old Nov 11, 2007 | 09:25 AM
85_SS's Avatar
Car: 1985 Monte Carlo SS
Engine: 5.7L
Transmission: WC T-5
Axle/Gears: 3.73:1
I'm installing a 92 W/C T5 into my Monte and am looking for the following parts:
-GM 14075712 - slave cylinder heat shield
-GM 14073767 - inspection cover (& bolts?) 1986-1992
-GM ????????? - 3rd gen clutch master cyl bracket (bolts to brake booster)
-trans to bellhousing bolts
-braces (2) that mount from master cylinder bolts to pedal assembly as seen here (under dash)
-female connector under dash for reverse lights (as seen on RHS of this pic ) from manual S10, F-body? or A/G body
The GM part numbers I have above are what I have found online, but it's possible some of them may be inaccurate - let me know what you have and we can go from there. I would prefer to buy as much from one person to keep the shipping costs down - so if you are parting a T5 3rd gen that would be perfect. I am in Canada and would require shipment through United States Postal.
Thanks,
Kevin
Old Nov 11, 2007 | 09:32 AM
tpi-hearse's Avatar
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
Re: WTB miscellaneous T5 parts
-GM 140694408 - F body lower shift boot
-shifter mounting bolts
-reverse light harness
The GM parts I have above are what I have found online, but it's possible some of them may be inaccurate - let me know what you have and we can go from there. I would prefer to buy as much from one person to keep the shipping costs down - so if you are parting a T5 3rd gen that would be perfect. I am in Canada and would require shipment through United States Postal.
Thanks,
Kevin
I have the lower shift boot and the 4 trans to bellhousing bolts..$30 shipped...I'll check on the other parts
Old Nov 11, 2007 | 11:08 AM
85SS/85GN's Avatar
gm part number for back up lights are 12085485
Old Nov 11, 2007 | 07:58 PM
85_SS's Avatar
Engine: 5.7L
Axle/Gears: 3.73:1
list revised - shift boot and shifter bolts received
Is this the harness itself? I'm not even sure if it's a seperate harness for the reverse lights - I believe I may have to make one.
Old Nov 11, 2007 | 09:25 PM
85SS/85GN's Avatar
it is a pigtail wiring from the transmission. it has about foot and half of wiring
Old Nov 11, 2007 | 09:31 PM
85_SS's Avatar
Engine: 5.7L
Axle/Gears: 3.73:1
great - thanks for the info!
Old Nov 25, 2007 | 12:59 PM
85_SS's Avatar
Engine: 5.7L
Axle/Gears: 3.73:1
I may have a slave cylinder heat shield located, but still looking for the rest
Old Nov 27, 2007 | 04:29 PM
85_SS's Avatar
Engine: 5.7L
Axle/Gears: 3.73:1
Now only looking for:
Old Nov 29, 2007 | 04:11 PM
85_SS's Avatar
Engine: 5.7L
Axle/Gears: 3.73:1
The following items are all I need to start the swap and apparantly can't be had aftermarket (or through GM). If anyone knows where they can be bought new, please let me know:
-85 Camaro Clutch fork spring (GM 472105)
-80 Malibu standard trans Neutral safety switch (GM 463496 or 469085?)
-GM 14073767 - inspection cover (& bolts) 1986-1992
-trans to bellhousing bolts (anybody know the size?)
Old Dec 5, 2007 | 07:36 AM
85_SS's Avatar
Engine: 5.7L
Axle/Gears: 3.73:1
Updated list:
-Bellhousing dust shield 1983-1985 GM 14079901 OR 1986-1992 GM 14073767
-Clutch fork spring (GM 472105)
-78-80 Malibu standard trans Neutral safety switch (GM 463496 or 469085?)
TA8487
Aug 16, 2015 12:21 PM
6948ric
Jul 12, 2009 10:46 AM
log93pow
Exterior Parts Wanted
Dec 19, 2008 08:53 AM
1 OF 162
Interior Parts Wanted
Jan 31, 2008 08:22 AM
