WTB headers/ypipe, carb, intake, perf parts NJ
Old Jan 2, 2008 | 08:31 PM
Isphius's Avatar
Car: 84 sport coupe
Engine: stock lg4
Axle/Gears: stock?
Hey, im looking for any random camaro or small block performance parts you may have lying around, including(all used) a square bore dual plane intake with or without egr, a good working holley carb <650cfm, a muffler that will fit in the stock dual exhaust location(magnaflow, borla, no flowmasters!) any header/y pipe combo that will bolt or be easily attached to the stock catback. thats about it for now so let me know! located in central NJ
Old Jan 3, 2008 | 04:36 AM
ted gerlach's Avatar
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
Re: WTB headers/ypipe, carb, intake, perf parts NJ
i have a set of headers edelbrock, with y-pipe, asking $150
i also have an intake to mount a holley on but no carb its still on the car the carb i cant sell the carb its not mine but i if wanted i will take the intake off asking $70 will have to get the make of the intake,
Old Jan 4, 2008 | 04:15 PM
theorio1025's Avatar
Car: 1984 Camaro Z28
Engine: 350 from an elcamino
Transmission: stock t-5
Axle/Gears: 10 bolt 3.73 limited slip
i have an intake and carb for your engine. the carb is a 600 cfm but its an edelbrock. it ran fine on my 82 z-28 w an l69 small block and a 305. ive got some other performance parts for that car too, such as an old school hei( non computer) with a summit kit.
Old Jan 9, 2008 | 09:15 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I have a set of Hooker 2055 headers and y-pipe, JetHot coated. PM me if you'd be interested.
Old Jan 9, 2008 | 09:39 PM
Isphius's Avatar
Car: 84 sport coupe
Engine: stock lg4
Axle/Gears: stock?
buying parts is on hold for a week or so, so ill let everyone know when i have cash in my hand instead of just beating around the bush
Old Jan 17, 2008 | 01:18 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
i have a wieand 7546 intake. it is a single plane. just throwing that out there
Old Jan 29, 2008 | 06:01 AM
Isphius's Avatar
Car: 84 sport coupe
Engine: stock lg4
Axle/Gears: stock?
Ive got some extra cash now but im mostly looking for either an air gap or performer RPM intake. something that will give me a few more rpms combined with exhaust
Old Jan 30, 2008 | 12:06 PM
the973camaroguy's Avatar
Car: 92 camaro rs
Engine: 305 tbi
Transmission: 700 r4
Axle/Gears: 2.77
do you still want the headers
Old Jan 30, 2008 | 12:52 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
I have a standard Edelbrock Performer. Will work under a stock hood. Be careful with the Air Gap's and RPM's. They'll fit but you'll need a 2" or better dropped based air cleaner....or a cowl hood. And it may not work with all carbs. If you have solid or poly motor mounts, it complicates the problem. PM me if your interested in the Performer.
Old Feb 27, 2008 | 09:33 AM
Isphius's Avatar
Car: 84 sport coupe
Engine: stock lg4
Axle/Gears: stock?
ok PMs sent still looking for a single 15 inch stock size tire, dual plane intake that will fit under stock hood, EGR blockoff plate, or any headers and y pipe that will end up very close to the stock cat or rest of the exhaust system.
Old Feb 27, 2008 | 11:18 PM
Isphius's Avatar
Car: 84 sport coupe
Engine: stock lg4
Axle/Gears: stock?
so far have sealed a deal on a muffler with tail pipes, headers/y pipe(thanks ted) EGR blockoff, and a performer manifold, so if you have any of the other parts let me know!
Old Feb 28, 2008 | 05:23 AM
Transmission: auto
i still have the headers and y-pipe
Old Mar 2, 2008 | 10:14 AM
Isphius's Avatar
Car: 84 sport coupe
Engine: stock lg4
Axle/Gears: stock?
PMed and only looking for a set of nice stock tires or one used one to match my 3 used tires
Old Mar 2, 2008 | 11:37 AM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
I have a carb that needs to be rebuilt, you can do it or I can do it for you, its a 650 vacuum secondary, single feed. I have a couple of cams if your interested in them also...PM Me if your interested...
Old Mar 5, 2008 | 08:28 AM
sngreen1's Avatar
Car: 1984 z28
Transmission: t-5
I have some edelbrock carbs in perfect shape if interested. reasonably priced!! let me know
Old Mar 5, 2008 | 08:44 AM
battz86's Avatar
I have a Speed Demon 750 vaccum secondary with less than 300 miles on it. If interested let me know.
midge54
Jan 29, 2017 07:00 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
TA8487
Aug 16, 2015 12:21 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
1nastygta
Aug 8, 2015 07:38 PM
