strut tower brace
Old Jan 9, 2008 | 01:53 PM
sadeks8's Avatar
Car: 91 Camaro RS
Engine: 3.1L MFI
Transmission: Hydra-Matic 4L60
strut tower brace
does anyone know where i can find a strut tower brace for a 3.1L? i've looked everywhere and they all say "for TPI only"
Old Jan 9, 2008 | 07:15 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Re: strut tower brace
If its the Multiport Injection set up i would think the TPI strut tower brace would fit it with no problems.
Old Jan 9, 2008 | 11:09 PM
sadeks8's Avatar
Car: 91 Camaro RS
Engine: 3.1L MFI
i called edelbrock and hotchkis and they said the TPI stb won't work on an MFI because the a/c compressor is in the way...but i looked and it doesnt seem like its in the way...
Old Jan 9, 2008 | 11:14 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
That could be true, the V6 accessories sit farther back in the engine bay than on the V8's. You may try placing a straight edge on the inner fender whells infront of the upper strut mounts and see where it sits compared to the AC compressor.
Old Jan 10, 2008 | 10:31 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Is the 2.8 MPFI the same externally as the 3.1? If so, I have a Hotchkis STB that I can try to fit on it and take pictures for you. Let me know.
Old Jan 10, 2008 | 10:41 AM
sadeks8's Avatar
Car: 91 Camaro RS
Engine: 3.1L MFI
well the compressor isnt really blocking the pass. side, but the master cylinder is basically on top of the driver side tower...has anyone built a custom stb for a v6?
Old Jan 10, 2008 | 12:03 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
The 2.8 and 3.1 are identical in size.
Here's a pic of mine to give you a hint at where it will sit, you mentioned the master cylinder on the drivers side but it will not hit it. The STB sits to the front side of the strut mounts on the strut towers.
Old Jan 10, 2008 | 04:55 PM
sadeks8's Avatar
Car: 91 Camaro RS
Engine: 3.1L MFI
ok so where can i get that exact one?
Old Jan 10, 2008 | 05:06 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Summit and jegs both carry Hotchkis strut tower braces. I dont htink they make the polished one anymore though..........jt
Old Jan 10, 2008 | 06:32 PM
sadeks8's Avatar
Car: 91 Camaro RS
Engine: 3.1L MFI
i went to both sites and there designed for fourth gens...but they will still work right?...heres the links if anyone else wants them
http://www.jegs.com/webapp/wcs/store...43986_-1_10069
http://store.summitracing.com/partde...796+4294908216
Old Jan 10, 2008 | 06:49 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
No, there a specific thirdgen STB. I looked and couldnt find them. Maybe they have all beeen discontinued.
I found them on Hawks website. Not sure what the Signature Series one is. Maybe its the polished one.
http://www.hawksthirdgenparts.com/in...ROD&ProdID=843
Old Jan 10, 2008 | 07:03 PM
sadeks8's Avatar
Car: 91 Camaro RS
Engine: 3.1L MFI
ok so do i have to drill the holes or does it just bolt on?
Old Jan 10, 2008 | 07:18 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
you have to drill 4 holes,2 per side.
Old Jan 10, 2008 | 07:30 PM
sadeks8's Avatar
Car: 91 Camaro RS
Engine: 3.1L MFI
what size do the holes have to be?
Old Jan 10, 2008 | 09:55 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
I dont recall, I believe they are 3/8" Bolts though so probably 7/16".
Old Jan 11, 2008 | 02:01 AM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
I got a TPI strut tower brace from a member here belive it was Bull if fit great on my 3.1 v6
If you want some pics giv3e me your email. Mine is already mounted and works great. Had no problem with the compressor or the master cylinder
Old Apr 9, 2010 | 05:08 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
I used a BMR- fit fine, after my son jumped up and down on it a little to make it fit flat on the shock towers...
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
