speed buffer
Old Apr 5, 2008 | 01:22 PM
kymission's Avatar
speed buffer
looking for a speed buffer, 92 firebird tbi 305. please let me know if you have one that works.
thanks
Old Apr 5, 2008 | 08:34 PM
Steve86TA's Avatar
Car: To many to list
Re: speed buffer
Are you taking about the yellow box under the passenger side dash?
Old Apr 7, 2008 | 07:06 AM
kymission's Avatar
Re: speed buffer
yes I am
Old Apr 7, 2008 | 07:50 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: speed buffer
PM Sent !
Old Apr 7, 2008 | 11:42 AM
wolfspirit187's Avatar
Car: 1988 trans am GTA
Engine: 350 V8 tpi roller motor
Transmission: 700-R4
Axle/Gears: 3.73 b/w posi will change out soon
Re: speed buffer
i was wondering i had that on my 86 ta what does that speed buffer do ?????????????
Old Apr 7, 2008 | 11:52 AM
kymission's Avatar
Re: speed buffer
On TPI cars the speed buffer is built into the ecm so those cars didn't have it. But on TBI cars the speed buffer was a unit by itself.
Electronic speedos was powered buy a vehicle speed sensor located in the transmission. This signal is sent to the speed buffer which then amplifies the signal and distributes it to three places. One being the ecm for engine management, second is the cruise control, and third is the gauge on the dash. It is not common for these to go bad since there is no moving parts (which I believe to be true). The issue that I have is that my ecm is getting correct speed signals based on my aldl laptop software as I drive. however the speedo is showing the incorrect speed. As a result, I believe the buffer is not doing its' job to amplify the signal correctly.
Old Apr 7, 2008 | 12:13 PM
87tpi350,6spd's Avatar
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
Re: speed buffer
I have some if you're still looking.
Old Apr 7, 2008 | 12:56 PM
kymission's Avatar
Re: speed buffer
"John in RI" has one that he is selling me. He has asked a fair price. I am going to try and get a new one from GM if possible I think I seen on this forum there GM has one new for $30.00. If this is the case I would rather spend $10.00 more and get a new one. But the I that posting was older and GM may not have it any longer so I probably will just get the one from John. Please pm me the info, cost, etc.. so I can have you as a fall back from john in rI
Old Apr 9, 2008 | 08:59 PM
6948ric's Avatar
Re: speed buffer
don't step in front of anyone i got a new one still in box from GM for a 1991 paid 40? if it will work take 40.00 shipped sold the car before part came in thanks
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
J.C. Denton
Sep 21, 2015 04:23 PM
Randomtask2
Sep 10, 2015 08:37 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
