need everything to convert from carb
Old Apr 22, 2008 | 11:25 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
just picked up a 98 searay 210 with 80hrs. The only thing bad is it has a 305 with a 2 barrell.. need more power. I want to put TPI on it.. so, I need everything to do it. I need a deal also because I am limited in the "FUN COUPON" dept. I'm sure one of you 305 guys can help me out with a good deal. Will a 5,7 l98 set up work? I think so
Old Apr 23, 2008 | 10:29 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: need everything to convert from carb
I would consider going to a four barrel set up with a good Holley Marine Carb. The problem with going TPI is that the electronics are not water proof. F car ECMs were mounted in the interior of the car because they can't handle the elements. Now the Corvette ECM will handle the elements as it was mounted in the engine compartment and is a lot more robust. But it's pricey. You will also need a wiring harness like the universal from Painless Wiring for the install. And you would have to purchase an external high pressure pump made for fuel injection.
A good four barrel manifold like a Performer Vortec, a set of Vortec heads milled to 58cc, a slightly bigger cam, and a 600 CFM marine carb would add an easy 80 hp and 75 ft lbs over your current set up...and be snap to install as compared to TPI.
Old Apr 23, 2008 | 10:43 AM
wesilva's Avatar
Transmission: 200R4
When I say Vortec heads, I mean 5.7 Vortec heads with the casting numbers 10239906 and 12558062. These have the power making port and chamber design. Your heads on the 305 are referred to as Vortec also, but these are not any where in the ball park with the castings above. The only negative is the chambers are 62 cc and yours are 58 cc. You will have to have the heads milled. If you keep your cam small with less than .465" of lift, you can use everything from your 305 heads...the rocker arms, pushrods and valve covers. If you are planning on going into salt water, then you will have to use the intake manifold on this link...
http://www.castheads.com/marine_vortec_2_4_barrel.php
Otherwise, as stated before, the Edelbrock Vortec Performer is the way to go.
By the way....I'm jealous. That's a great boat.
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
andy74
Sep 3, 2015 08:41 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
