Need L98 Cam and 85 memcal
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
I am doing a 350 swap very soon and I was told I need an L98 flat tappet TPI cam years 85 or 86 and an 85 L98 memcal.
I'm on time restraints here so anyone who can sell me these parts please let me know.
Thanks.
Thanks.
Car: 1986 WS6 TransAm
Engine: THREEFIDDY!
Re: Need L98 Cam and 85 memcal
85-86 L98 flat tappet cam, and an 85 350 memcal.. there around!
Bump to firedemon!!
Bump to firedemon!!
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
you cant reuse a flat tappet cam over again without having the lifters with it and the lifters need to match the lobe they were riding. not worth the effort
new mild flat tappet cam kits are under 200 bucks, get a new one
If you wanted a roller cam and roller lifters i have that for a 89 L98
Car: 89 Iroc-z
Transmission: TH400
yeah but i dont see why you would want to do that when new better cams are available over mid 80's tech. oh well, bump for you
Car: 1985 Z28
Sorry It's a PROM I need NOT a MEMCAL.
If any mod catches that please edit it into the title.
Car: 1983 G20 Chevy
Transmission: 4L60
Guess what, a L98 F-car prom for 1985 does NOT exist. You could possibly use one for a L98 Vette though.
Car: 89 Iroc-z
Transmission: TH400
Forgot about that, i just assumed 85 L98 you mean vette L98. Why do you need a 85 cam and prom to do a 350 swap?
you probly can run a 87-89 L98 prom with flat tappet cam of similar size to the L98 85 cam. Your probly never gonna find one with lifters so might as well consider roller L98 like factory or new flat tappet. Super tight budget i can understand but your doing a motor swap and cant drop like 150 bucks for a new cam? cam seems to be the smaller part of the whole investment
else check out corvette forum for those parts as they had L98s in 85-86
Car: 1985 Z28
Here is the problem.
I am swapping the TPI setup from my 305 to the 350, but the wrong lifters were used in the 350. The guy said it SHOULD be ok as long as hydraulic flat tappet are used (It's a '72 engine), but I've been told I need an L98 350 specific cam and an ECM/prom to match. That's what I've been basing all my searching off of. Now I'm getting several different stories and TBH, at this point I have NO CLUE what lifters, what cam and what ECM/Prom I want to be using. I was under the impression that the cam from my 305 wasn't a good idea.
What about CompCam 12-388-4, new set of lfat tappet lifters from summit and a 1985 corvette (L98) ECM?
Last edited by FireDemonSiC; May 13, 2008 at 11:49 PM. Reason: Automerged Doublepost
Car: 89 Iroc-z
Transmission: TH400
Could start a new thread for this but that setup will work just fine with just about any L98 prom if its a MAF system. SD may need some tuning but that cam is about same size as stock L98 cams and should work
IF all your doing is a basic 350 swap to make your car just like a factory L98, then yes use that flat tappet cam with new flat tappet lifters and a ECM/Prom for fbody L98. year depends on what your car is. What year is your 305 TPI car? reuse the stock MAF if its MAF and ECM, just get a PROM for a L98 car
it will run fine. heck you could go up one size on the cam with MAF system and still run ok
it will run fine. heck you could go up one size on the cam with MAF system and still run ok Thread
