Need a Block
Old May 25, 2008 | 11:43 AM
iroczcamaro87's Avatar
Car: '87 Iroc camaro
Need a Block
Blew my main bearing in my '87 TPI 305. Looking for a longblock 350. Thanks ahead of time!
Old May 25, 2008 | 09:48 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: Need a Block
pm sent
Old May 29, 2008 | 11:40 AM
MartinD's Avatar
Re: Need a Block
Did you find one yet?
Old May 29, 2008 | 05:41 PM
Re: Need a Block
Not yet still looking. Do you have one?
Old May 31, 2008 | 07:02 AM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: Need a Block
pm sent
Old Jun 1, 2008 | 04:33 PM
smallblockking's Avatar
Re: Need a Block
i have 1 from an 89' gta. 2 bolt main, roller cam style
hot tanked, baked & blasted, magged for cracks. standard bore.
ready for machining.
$250.00.
Old Jun 1, 2008 | 07:16 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
Re: Need a Block
I have a 4 bolt main short block, w/forged pistons, Meling oil pump, line bored and internally ballanced. it is a 355 and I have reciepts for everything, plus it can be a long block if so desired. It has about two hrs dyno only run time on it. I used it to test and compare different head and cam combos. You can find a similar short block at summit for around 2000.00. Make me an offer and I will consider. Right now it is bagged and on a skid. Fogged down of course!
Jeff
Old Jun 1, 2008 | 09:18 PM
Re: Need a Block
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Old Jun 1, 2008 | 09:49 PM
85gulstrandTA's Avatar
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
Re: Need a Block
I have 2 sbc's I need to sell. 1st one is 350 virgin, 4 blt, magged, hot tanked and ready for machining. $250
2nd one is a short block 350 4 blt, bored 60, trw pop-ups with small domes, line honed,balanced, stock crank rods, comp 306 solid cam 260 @50 int/e . double roller timing chain, studded bottom end, cromemolly rod bolts. $1,250
2nd motor would be high hp with good heads,intake,exshaust high 400 hp maybe a honest 500 or aproaching at the crank with a good tuner.
Problem is I'm in So Cal and I know shipping will make the total cost involved a problem.
LMK
Old Jun 2, 2008 | 03:43 PM
Re: Need a Block
yeah i was thinking the same. I'm not making any trips to So Cal soon so i dont thkink it would work out. Im just curious how much would shipping be on the first SBC?
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
