wtb: t-5
Old Jun 28, 2008 | 01:15 AM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
wtb: t-5
looking to buy a complete t-5 swap, includeing center consle. possable shipped to 24015 if i cant not pick up
Old Jun 28, 2008 | 08:19 AM
85TAracer's Avatar
Car: 1985 Trans Am
Axle/Gears: 9 Bolt posi disc 3:27's
Re: wtb: t-5
I have all the swap parts except the center console piece, The trans needs the 3-4 syncro rebuilt/replaced I just don't have the time to do it anymore. It comes complete with clutch assem. and flywheel so you know what to get if you wanted to upgrade them. I will check to see if I even want to ship the tranny, it is heavy....but I would deffinately ship all the other swap parts...then you would only need a tranny that you might find local.
Parts include:
clutch flywheel pressure plate bellhousing all hydraulics (slave cylinder, master, and line) clutch and brake pedals I'm thinking $250 plus shipping for these parts
Old Jun 28, 2008 | 02:43 PM
DARKmj16's Avatar
Engine: 305 tbi
Re: wtb: t-5
great, but unforuntily i cant find the trans here. and mailing does seem like a lot...so if it comes down to it then road trip!!! that would be fun, ill let you now, im gona wait a little longer to see if anyone else posts
Old Jun 28, 2008 | 05:25 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: wtb: t-5
Got a good condition 91 WC V8 T5, trans only $600 shipped.
Old Jun 28, 2008 | 06:30 PM
85TAracer's Avatar
Car: 1985 Trans Am
Re: wtb: t-5
Oh, I forgot to add, this is also from a 1991 Firebird V8...so WC V8 T5. And, I also forgot to add if you wanted everything including the trans- $550
P.S.- dont be afraid of the 3-4 gear problem, I almost gaurantee it only needs blocking rings, which there are 2 of them, one for each gear, and they run about $18 each, and I bet a tranny shop would put them in for cheap, since its the easier side of the shaft to take apart. The trans still shifts into the gears, but it will grind a little bit sometimes into 3rd and into 4th. The rings are just getting worn out from use.
(in case you havn't noticed I have experience with these transmissions)
Old Jun 28, 2008 | 10:41 PM
DARKmj16's Avatar
Engine: 305 tbi
Re: wtb: t-5
85TAracer, does it fit into a 88 camaro? ik i should now this already, but i like to make sure b4 wasting money. if it does then that sounds great, ill need a little time b4 i can get the time off from work, but i will keep updates gon
Old Jun 29, 2008 | 07:36 AM
85TAracer's Avatar
Car: 1985 Trans Am
Re: wtb: t-5
yes, all of the trannys are the same, as are the cars, so everything will swap just fine. Send me a PM if you want to work something out.
Old Jun 29, 2008 | 03:08 PM
DARKmj16's Avatar
Engine: 305 tbi
Re: wtb: t-5
PM sent, sale pending will update
Old Jun 30, 2008 | 07:30 PM
JN56's Avatar
Car: 1987 Formula 350
Engine: 5.7 350 TPI
Transmission: 700R4 w/ shift kit
Axle/Gears: 9 Bolt BW 3.27
Re: wtb: t-5
85taracer. If the deal doesnt go through can you pm me? dont mean to step on feet.
Old Jul 4, 2008 | 09:42 AM
87_GTA_5.7's Avatar
Car: 1987 Pontiac GTA Trans Am
Engine: Basic Stroked SBC..383
Transmission: PerformaBuilt 700R4 3000 Stall
Axle/Gears: Moser 9in. 3:70s
Re: wtb: t-5
I bought the kit from hawks to do a man. swap. Im not going to use it. I have all but flywheel clutch and console stuff. All in boxes still
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
