looking for a super ram , miniram or aftermarket tpi runners and intake. also bigger throttle body and a hot cam or other comparable aftermarket cam
for 300 you can have my slp runners (no cold start) with my matched plenum. both clean used for only 1k miles or so. comes with bolts and no throttle body. the runners are slights ported where theyre siamesed plenum side. the plenum has throttle bores opened, walls smoothed, egr walls ground down, and the runner holes are siamesed matching the slp's exactly.
i also have a ported stock base for sale. its ported on both the head side to match the intake manifold gaskets(felpro) and on the runner side its opened up and smoothed. comes with EGR valve(working). painted and clean, a grey with a clear coat. will sell for 75.
Designed for a small block chevy factory roller motor.
XM270HR Comp Cam, hyd roller cam, 218/224 duration, .495/.503 lift 112 lsa 110 intake centerline
Great cam, can be used in a computer controlled motor also.
$100
918-527-5316
$100
918-527-5316
Want a title? Post!
are you still looking for a cam, i have a slightly used SLP cam for TPI
224/232 .490/.510 112 LSA
I have an Accel DFI for sale.
Will
Will
Want a title? Post!
i have a complete intake with almost new throttle body for 400
Still Looking for a Super Ram ? Mine is for sale. Complete base, runners and upeer plenum. (listed on F-body.com, Corvette Forum and craigslist, Atlanta, GA) Dave
I have a set of SLP runners $275 also stock runners,manifold,fuel rail,plemun. Plus all shipping cost
Quote:
I have a Super Ram complete, large intake base, Large Runners and the large plenum. Entire set for $800. All you need are gaskets, throttle body, injectors, ( I have 8 flow matched 24 lbs ford injectors for $ 200.) Uses stock fuel rails and regulator. Used reverse profile roller cam, 234/232 at .50 and .508/.512 lift used. $100. Good shape when removed. E-mail if you are interested. Davidnsue@comcast.net Thx, DBOriginally Posted by gary68
looking for a super ram , miniram or aftermarket tpi runners and intake. also bigger throttle body and a hot cam or other comparable aftermarket cam Junior Member
im sellin a holley stealth ram, with injectors and fuel rail, and 58mm airzona speed and marine throttle body for 450 dollars
24lbs injectors. i have 30lbs injectors for sale seperately.
I have a set of SLP runners bearly used. Never had fuel in them. $275 free shipping in the 48 states.
Sketchy,Originally Posted by sketchy
im sellin a holley stealth ram, with injectors and fuel rail, and 58mm airzona speed and marine throttle body for 450 dollars----------
Are you willing to sell the 58mm TB separate ? Blueray 2
i just posted a 58mm accel billet throttle body in the for sale forum
